Tutorial Another simple arduino dashboard with TM1638
Discussion in 'DIY peripherals' started by vthinsel, Sep 22, 2015.
  1. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Read your project, I have been able to complete my own TM1638 dashboard, and thank you!
  2. Slimsign
    Slimsign New Member
    Tynaarlo
    181Coins
    Can you please tell me if it is possible to get it working on a ps4... Thank you !
  3. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,026Coins
    Arduino, 4DOF
    as long as the game plugin supports gamedash and PS4 game, it works. I myself use PS4......
    PS4 supported games : project cars, project cars 2, assetto corsa, F1 2016 , F1 2017 and maybe some others
  4. Walt
    Walt New Member
    17Coins
    Smoked regulator, interesting. Don't see how as the VUSB does not go through the regulator. Only Vin goes through the regulator using 9 or 12 Volt input. I use the TM1638 on USB power without a problem. Just don't overload the computers USB port, Use a powered hub if any question. Anyways, a cool project.
  5. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    108Coins
    Any idea what RPM output rules I have to change so all the leds lightup when I have full RPM? Only the first 5 leds are on, they other 3 are alway off even with full rmp,
    Hans
  6. vthinsel
    FRANCE
    6,026Coins
    Arduino, 4DOF
    Hi !
    Send a /Txxxx command where xxxx is the max RPM.
    Send it only once
  7. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    108Coins
    Thanks, what do you mean with Send ?Txxxx where do I do that?
  8. vthinsel
    FRANCE
    6,026Coins
    Arduino, 4DOF
    In the dash output settings
    Note, that I didnt validate the config shown here, it is just an example.
  9. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    108Coins
    I tried differnt values but still the same result, when the car is in N, 2 leds light up and with full RMP 5 leds light up.
  10. vthinsel
    FRANCE
    6,026Coins
    Arduino, 4DOF
    can you put screenshots of the dash output settings ?
  11. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    108Coins
  12. vthinsel
    FRANCE
    6,026Coins
    Arduino, 4DOF
    This cant work as the board will receiver <La1><Sp1> making L unreadable, and no speed update as well
    as per the documentation:
    Serial/I2C syntax: [command letter][decimal number]
    // Yx : Start module with intensity set to x (1-7)
    // Sx : Speed update (decimal notation)
    // Gx : Gear update (decimal notation)
    // Rx : RPM update (decimal notation)
    // Tx : Max RPM
    // Ox : oil temp
    // Wx : water temp
    // Fx : fuel
    // Lx : lap
    // Px : position
    // Exxxx : lap time. 4 bytes representing float according to IEEE
    // Z0A : Stop and clear module
    The command will be processed when a new one starts. For example, RPM will be updated on the module once a new command such as S will start
    Serial data to start with max luminosity set (5), speed=95, RPM=4250, gear=2, lap=3, position=12 (last caracter is to finish processing of RPM, can be anything except a digit)
    Y5S95G2R4250T5000L3P12R
    If gear is negative, the reverse is assumed and 'r' is displayed
    If gear is 0, neutral is assumed and 'n' is displayed
  13. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    108Coins
  14. Piwolf
    Piwolf New Member
    - 49Coins
    Thanks vthinsel !
    My Mini Cooper R53 instrument cluster works after I moded some codes.
