Cytron 2DOF sim w/tloss
Discussion in 'DIY Motion Simulator Projects' started by 90kgOver300m, Apr 18, 2023.
  1. 90kgOver300m
    90kgOver300m Member
    Maintenance technician
    United Kingdom
    263Coins
    Hi all.
    I'm planning on starting my first motion rig soon, this is my first post where I will describe my spec / plan. Due to this being my first rig, any comments and considerations of my design that I may have overlooked will be greatly appreciated.
    Spec as follows:
    3x 24V 480W 20A LED PSU's
    3x 24V 250W 75rpm wheelchair motors 23:1 worm-gear (which I calculate to be about 30Nm and a constant current of 10A)
    3x 5V 180 degree, 10k hall sensors
    3x 6V - 30V 20A Cytron single channel motor controllers
    1x Ardunio Uno Rev3
    The fabrication of the rig will be mainly using 30 x 30 x 3mm mild steel box section and angle iron, with 75mm of adjustment vertically and horizontally on the wheel, with about 200mm of adjustment on the seat with sliding rails. Pedals will be fixed.
    The 2DOF motor linkage will be mounted at about shoulder height.
    All peripherals will be mounted to the motion platform, with exception of monitors.
    Blame's modified Cytron code will be used in the SMC3 software.
    Finally I have a few questions if anyone is able to help :)
    I've seen posts about regenerative current causing issues with PSU's and motor controllers. I'm hoping that by giving my PSU's 230W of headroom I can avoid the use of batteries in parallel to keep the control box footprint down, is this true or will I still need batteries?
    Will the Arduino power be enough to power my 3 hall sensors?
    I would finally like to thank everyone for the knowledge shared across the forum and the FAQ section, I wouldn't have known where to start without it.
    152,700Coins
    +11,091 / 56 / -2
    The amount of power spikes in fast reversals is hard to predict, given there are a range of variables involved. Personally I use 3 x 600w PSUs.
    Hall sensors don't have significant power requirements, via the Arduino will be fine.
  3. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Ideal, less cables, and have you ever had any issues running with them psu's?
    152,700Coins
    +11,091 / 56 / -2
    No, the PSUs have been fine, despite considerable loads.
  5. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Back from holiday and finally have everything I need to make a start. Few bits left to make / order but will cross that hurdle when I get to it.
    Fabricating seat frame and mounting it to seat brackets and sliding rail
    Main section of cockpit frame, which wheel frame and pedal frame will attach to.
    Hoping to find some dimensions online for the pedals I'll be ordering, so I can possibly make a template and work out the pedal frame.
  6. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Turned some adaptor pieces to attach motor shafts to hall sensors
    Also more progress on the cockpit frame, found some dimensions for pedals and made a template out of cardboard
    Then metal
  7. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Made the wheel bracket, cockpit almost done just pedals to mount next
  8. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Got the pedals mounted then couldn't wait to try the cockpit alone while waiting for some parts, back in pieces now.
  9. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Finished the construction, now waiting on PSU's.
    Seen a few posts about people making hard stops for when the rig is stationary with wormgear ratios less than 50:1, is this purely just for ease of getting in and out? Or will the smc3 software lose its reference on the hall sensors if powered down and moved?
    152,700Coins
    +11,091 / 56 / -2
    If the rig is properly balanced, stops are generally about ease of getting in and out, but I would not suggest adding them until the rig is fully sorted and tested, just in case you have an unexpected runaway situation, as that can cause damage if there are hard stops.
  11. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Thanks for the reply, apologies for my bad description but I meant more of some sort of hinged stop or pin that folds completely out the way, not a physical hard stop for the rotation of motors. I won't mind the rig moving about when getting in / out as long as when powered up it retains its correct home / level position.
  12. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    It's finally alive, very happy with how it feels and motion is even more agressive than I expected.
    Haven't connected up the traction less yet, it's ready but the roller wheels have flats on them so require an upgrade before using.
    At slower speeds when accelerating / braking, the motion is too much and feels like it's vibrating, anyone have any tips on how to reduce this? I'm assuming its my SIMTOOLS settings.
    1st test video:
    v=SPLsYQIY1yw&ab_channel=Aaron
    My current SIMTOOLS settings:
