Resolved SMC3 Utility Not Working
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Daniel Nagay, Feb 12, 2023.
  1. Daniel Nagay
    Daniel Nagay New Member Gold Contributor
    35Coins
    I am currently building a 2 DOF Racing simulator and am currently testing out the motors and the program before the full build to make sure it works. I am following the thread
    I got to the part where I use SMC3 Utility to make sure motors work and to properly tune it. I was increasing my PWMmax up and the motor never ended up spinning and I was already around 100. Not sure why that is. I would love to see if someone knows why it would be like that.
    Something that I noticed is that my potentiometer (green) is at a very low position and not towards the middle. After I got to 100PWMmax I decided to twist the potentiometer and see if its working still but it will only have movement in the last 90% of the twist and spike up like in the image. The potentiometer I use will be linked below. Has anyone used these potentiometers?
    https://a.co/d/5BuOYUE
    Also I am pretty sure I burnt out both of my motor controllers after twisting the potentiometers because they smelled burnt. This is how I had everything for testing.
    Thank you.
    153,986Coins
    +11,162 / 57 / -2
    Was the code set to Mode 2 for the IBT2s?
    Are the pots connected to the motors?
  3. Daniel Nagay
    35Coins
    Yes the I changed the mode to 2.
    They were not attached, I am going to 3d print mounts later for them.
    I kept messing around and twisted the pot to show the green line above the motor line and it worked for motor 2. I am almost positive somehow the first motor controller ended up frying itself.
  4. Allwin Joseph
    Allwin Joseph ajstan
    Student
    Bengaluru,India
    12Coins
    What motors are you using?, are they ground isolated? if not the IBTs will burn out quickly ( especially with wiper motors),
    check if any of the motor's wires are connected to the motor housing, you can do this with a multimeter in continuity mode.
  5. Daniel Nagay
    35Coins
    I am using the 12v crab pot motor from Canada. The motor that DMax was using in his video
    https://www.ebay.com/itm/3540520763...TLzj8WYgAqYAnAlc6dvNC5RkY=|tkp:Bk9SR4aKoe3IYQ
    153,986Coins
    +11,162 / 57 / -2
  7. Mattlekim
    Mattlekim Member
    - 5Coins
    Swap the h-bridges around. If the problem persists it's not the h-bridge that's burnt out.
  8. Daniel Nagay
    35Coins
    Thank you everyone for your help. I figured out the issue. I was being dumb. So if anyone stumbles upon this post and they have the same issue that I did, this is how you can fix it.
    What went wrong: It's always the darn wiring. The way the potentiometer works is it has the positive/negative leads on the end and the range pin is in the center. I was being dumb and the potentiometer that I bought as shown in the picture isn't wired that way. I assumed that maybe there is a reason why black was in the center and yellow was on the edge so I plugged negative to black and Pin A0 to yellow.(WRONG)
    What to do: In fact now that I read some more about the potentiometer I decided to plug the black wire(center wire) to A0 and it worked.
    Lesson Learned: Never trust the wire color from manufacturer!
