Question Dirt Rally 2.0 weird min and max values
Discussion in 'SimTools DIY Version' started by Nicki9knuckles, Jan 12, 2023.
  1. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    740Coins
    3DOF, DC motor, Motion platform
    Hi there, I am getting some really weird values when I try and run Dirt Rally 2.0. I tried in both Simtools versions and both show different values. Fyi this is after me carfully driving without hitting anything and going around a few turns and hills. When I run this profile at full intensity level, my motors just jump around. I tried lowering it to 80 and nothing is moving in a logical way, like the axis3 is shifted to one side, and my axis 1 and 2 are not really moving. Not sure if anyone ran into this before. And the roll input is NAN in the new SimTools. Not sure why that would be.
    Thanks!
    dirtrall2-werid-min-max.JPG dirtrally2-axis-settings.JPG dirtrally2-ols-simtools-weird-capture.JPG
  2. yobuddy
    50,828Coins
    Looks like the same problem in wrcg, I will take a look.
    Thanks!
  3. Nicki9knuckles
    Web Developer
    740Coins
  4. Nicki9knuckles
    Web Developer
    740Coins
    @yobuddy just a heads up that this seems to only be an issue with the plugin inside of SimTools v3. I was just testing SimTools v2.5 with Dirt Rally 2.0 and it works like a charm.
  5. yobuddy
    50,828Coins
    @Nicki9knuckles,
    I pushed a new Dirt Rally 2.0 v3 plugin to the repo earlier today, maybe let it update and give it another shot.
    Thanks buddy!
  6. Nicki9knuckles
    Web Developer
    740Coins
    hey @yobuddy I just gave the update a try. I seen it was available in Simtools v3, and downloaded it. Then I booted up DR2 and got though all the menus but as soon as I get to the race, Simtools crashes. I reproduced this the 2 times I tried, booting it up a second time and relaunching DR2.
  7. Nicki9knuckles
    Web Developer
    740Coins
    @yobuddy let me know if there is any logs or anything useful I can send you to help if you want.
  8. yobuddy
    50,828Coins
    Please remove the plugin all together and restart v3.
    Then reinstall the plugin and give it another go.
    (It's using different patching now, so I think it did not patch correctly is all.)
    But we will see :D.
    Chat soon!
  9. Nicki9knuckles
    Web Developer
    740Coins
    hey @yobuddy ! You were right! Uninstalling the patch first fixed it, things are working perfectly now. Nice work!!
