MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    what should i do? is it gear problem? (Both side)
    153,884Coins
    +11,154 / 57 / -2
    Backlash is common in wormdrives: https://www.xsimulator.net/community/faq/wormdrive-backlash.293/
    The longer the leavers the more pronounced the effect.
    A little bit of positive weight bias will help mask the back lash. An alternative is gas struts or elastic cord.
    It may be possible to shim a wormdrive, but in the end some back lash exists for lubrication purposes.
  3. absyfadhel1
    bahrain
    556Coins
    left motor move more than right in simtools, smc3 work all good and move the same.
    also i use now hall effect potentiometer but its look like 100k pot, in smc3 this is max and min level i can reach in my rig now unlike 10k pot i use before
  4. absyfadhel1
    bahrain
    556Coins
    this is my simtools setting
  5. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    170Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hey! I recommend not to use any adapters (USB extension cords).
    Use these:
  6. absyfadhel1
    bahrain
    556Coins
    i test without the usb extension but no diffrent.
  7. kalbasator
    Kazahstan, Almaty
    170Coins
    You don't happen to have a limit:
  8. absyfadhel1
    bahrain
    556Coins
    i limit axis to save my rig becuase pot move so large , i tried yo make limit 100 for all and test but its give same problem, left motor movebmore than right
  9. absyfadhel1
    bahrain
    556Coins
    BHD 0.54 39%OFF | 1/2Set GT2 Synchronous Wheel 60 Teeth 20 Teeth 8mm 5mm Bore Width 6mm Aluminum Timing Pulley with Length 200mm Belt with Wrench
    https://a.aliexpress.com/_mLlGv0Q
    which one should i buy?, i use 360 hall effect
  10. kalbasator
    Kazahstan, Almaty
    170Coins
    Hey! If you use 60/20 then the lever will work in a partial range, something like this:
    It might be better to use 60/40. But I may be wrong.
  11. absyfadhel1
    bahrain
    556Coins
    Thanks so much , i will buy 20T-(40t and 60t)
    better so i will check both
  12. absyfadhel1
    bahrain
    556Coins
    try every single setting in smc3 like
    lowering pwMin
    Kp higher or lower
    Ki lower
    kd higher until 200
    ks high and low
    nothing help, the motor mounted corecctly, pully tighted , all wires replaced, diffrent arduino, changed lever angle, Pc reigon is set to Us engilsh ....
    what should i do??
    i think ist because motor lash , please suggest best box ratio, 25:1 60:1... whish size is the best ?
    motor power is 12v 300w 60rpm
    i think 60rpm is still good for this right? or should i replace the motor?
  13. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    What happens if PWMmin is 20, kp 400, PWMmax and PWMrev are set 20 over whatever the rig starts to move at?
    How well balanced is the rig and how was that done?
  14. absyfadhel1
    bahrain
    556Coins
    i know what the problem,... motor move has backlash or idont know what called, like its moving the lever when its idle, so i need new motor, give me suggest for best motor size , ratio, rpm, watt
    153,884Coins
    +11,154 / 57 / -2
    Some backlash in a wordrive is normal and required for lubrication: https://www.xsimulator.net/community/faq/wormdrive-backlash.293/
    Can you demonstrate why you think yours is excessive?
  16. absyfadhel1
    bahrain
    556Coins
    because when i let pull the rig to rear while testing smc3 there is no shake and move smooth, so i'm thinking now to use gas strute because as i saw on some thread that all worm gear has slake backlash
    153,884Coins
    +11,154 / 57 / -2
    Have you tested it with the top platform disconnected?
  18. absyfadhel1
    bahrain
    556Coins
    i didn't understand what you mean? sorry can you expline ?
    153,884Coins
    +11,154 / 57 / -2
    If you disconnect the arms to the top platform do the motors behave the same, or differently?
    Backlash can be an issue, but all I am suggesting is that there may also be a range of possible causes and best to investigate rather than presume.
  20. absyfadhel1
    bahrain
    556Coins
    oh ok i will check
