Question several functions with one arduino possible ?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by sci666, Jul 28, 2022.
Tags:
  1. sci666
    1,210Coins
    Hi there,
    i just ask myself, is it possible to use one arduino (leonardo, whatever) to control several things.
    for example: a clutch pedal, a handbreak lever, a shifter LED and a Wind simulator ?
    for pedal and handbreak it should work because its just like a pedal cluster for 2 or more potentiometers right ? its just a mapping thing in the game which potentiometer are used for clutch and brake.
    but can the same arduino handle the other things in parallel or do i need one per issue ?
    thnaks :)
    154,022Coins
    +11,163 / 57 / -2
  3. sci666
    1,210Coins
    okay thanks for the links, so i see everything for input can combined in a single arduino. buttons and poti´s.
    but i dint see a combined input AND outpud device like buttons + wind simulator ... but maybe its a coding issue to run both things in parallel ?!
    154,022Coins
    +11,163 / 57 / -2
