Showroom Prototype DIY 3-DOF motion platform – Arduino + 3x BTS7960 + SMC3
Discussion in 'DIY Motion Simulator Projects' started by krause-a, Nov 2, 2020.
  1. krause-a
    krause-a New Member Gold Contributor
    46514 Schermbeck, Germany
    124Coins
    3DOF, Arduino
    Here are the SMC3 settings.
    The Kp value with 200 and the PWMmax with 200 are relatively low. But so it still works well.
    At higher values, unfortunately, the motors will be very warm and sometimes switch off the motor drivers.
    I am currently thinking about an active cooling of the motors to increase the Kp value and the PWMmax value.
      20.9 KB
      550
  2. Gustau
    Gustau New Member
    Barcelona
    213Coins
    Did it work?
  3. Joe Cortexian
    1,549Coins
    “I found the reason for this in the program SMC3.ino.
    The subroutine Parsecommand contains the line
    "Serial.println(RxBuffer[0][ComPort])"
    I have commented these out.”
    I am also having an issue with smc3 but when I do a search of the source I do not find any Serial.println at all in the smc3 source. Your screen shot says version 1.00 but I don’t believe that code has that line of code. So apparently we don’t have the same source code.
  4. krause-a
    124Coins
    3DOF, Arduino
    Hi, yes it works.
    I have now been able to integrate a water cooling system.
    I have rolled copper tubes around the motors. Between the motor housing and the copper tube there is a heat conducting foil.
    The pump conveys the heated water through a radiator for cooling.
    Without cooling, the engines had heated up to over 80°C. With cooling it is now below 40°C.
    • Creative Creative x 2
  5. krause-a
    124Coins
    3DOF, Arduino
    You are right. I must have downloaded some modified code somewhere
