Dimensions of a 2DOF motion platform for SimCalc
Discussion in 'DIY Motion Simulator Projects' started by imajavaid, Nov 16, 2021.
  1. noorbeast
    152,700Coins
    +11,091 / 56 / -2
    This was your earlier settings, what changed:
  2. imajavaid
    imajavaid Member
    169Coins
  3. imajavaid
    imajavaid Member
    169Coins
    These are my settings. One motor is working fine. Other is causing the issue
  4. imajavaid
    imajavaid Member
    169Coins
    https://www.xsimulator.net/communit...only-move-in-one-direction.15582/#post-212298
    I followed this suggestion but it didn't work
    152,700Coins
    +11,091 / 56 / -2
  6. imajavaid
    imajavaid Member
    169Coins
    Im not using simtools in this step. Only step Im trying to copy is to move motors manually trough smc3. one motor is working fine other motor is just moving in one direction. How to solve this issue
  7. imajavaid
    imajavaid Member
    169Coins
    Im thinking of rewiring the connection to arduino, motors and pot . Will it help
    152,700Coins
    +11,091 / 56 / -2
    It could be an issue with the Arduino itself, or control boards, given the hardware you are using. If you swap hardware around side to side does the issue move or remain the same?
  9. SteULM
    SteULM Active Member
    600Coins
    Hopefully the driver hasn't burned out ....
  10. imajavaid
    imajavaid Member
    169Coins
    I will swipe the motor driver and then look into the problem
  11. imajavaid
    imajavaid Member
    169Coins
    Is there any method to check whether the driver is burnt or not
  12. SteULM
    600Coins
    Try checking the wiring first
  13. SteULM
    600Coins
    You can try reversing the drivers to see if the problem always shows up with the same
  14. imajavaid
    imajavaid Member
    169Coins
    My driver is burnt. I swap the driver and motors worked perfectly
  15. imajavaid
    imajavaid Member
    169Coins
    Is there any way to measure how much my platform has roll and pitch in comparison to the roll and pitch of Xplane. In other words I want to measure how much amount of roll and pitch my platform has gone in real time against the 15 or 20 degree roll or pitch of aircraft in Xplane.
    Can I compare the motion angles of platform and the game. Is there any way to do that
  16. noorbeast
    152,700Coins
    +11,091 / 56 / -2
    I am not certain what you have in mind but hope the SimTools remote profile may assist: https://www.xsimulator.net/community/marketplace/simtools-v2-remote-profiler.172/
  17. imajavaid
    imajavaid Member
    169Coins
  18. imajavaid
    imajavaid Member
    169Coins
    If I reinstall the game. Do I need to repatch the plugin. Or the previous patched plugin will works fine
  19. imajavaid
    imajavaid Member
    169Coins
    How to patch the plugin with the reinstall game. How to unpatch the plugin from the previous installed game( that crashed and I had to reinstall the game).
    152,700Coins
    +11,091 / 56 / -2
