SimTools v3 Alpha (Questions, Answers, Fixes, Show & Tell)
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Mar 17, 2022.
Thread Status:
Not open for further replies.
  1. llluis
    Quebec
    1,630Coins
    So, it seem I'm on v3:
    There's a v4:
    But I don't have the update notification:
  2. yobuddy
    50,831Coins
    @llluis,
    Rich is working on the versioning numbers right now lol.
    But we checked and its offering the newest update.
    Notice if you click download, it gives you version 4 also.
  3. yobuddy
    50,831Coins
    Plugin Versioning on the Repos data pages completed! :thumbs
    (They now simply show the last version uploaded.)
  4. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Tested and all OK
  5. Tim Palmgren
    Tim Palmgren Maker / Motion Fanatic
    IT Recruiter
    Auckland, New Zealand
    82Coins
    3DOF, Motion platform, 4DOF
    Happy with the smoothing now, will plug away at it and see if I can get some passable tunes together.
    Successfully ran an old 911 into the wall on Nordschliefe without requiring major dental work :thumbs
  6. llluis
    Quebec
    1,630Coins
    I know I can download it and install manually. But the alpha idea was to check the online delivery options, right? :)
  7. llluis
    Quebec
    1,630Coins
    So there's no way to confirm the version I have installed anymore? I still believe I don't have the lastest one. Unless you tell me to forget the automatic updates and I will donwload the file from the webpage.
    I restarted SimTools, changed repos and didn't get the update available notification.
  8. yobuddy
    50,831Coins
    Open the data page for the plugin, it holds all info for the plugin...
    We can have it other places, but this is the place to check for now.
    Just changing repo's won't automatically trigger an update, there has to actually be an update available is all.
    Since you had the options on automatic, you probably already have it.
  9. yobuddy
    50,831Coins
    Yes, my point is its sending out the same version it's offering for download.
  10. Historiker
    9,208Coins
    Edit: Really liking the game plugin links with further information.
    Error while trying to update LFS plugin:
    Error Log: 4/8/2022 : General Update Error 3
    Error Log: 4/8/2022 : General Update Error 1
    Code:
    System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
       at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
       at SimTools.MyGamePlugins.Cls_GamePlugins.ReloadPlugin(Int32 PluginID, Boolean Licensed)
       at SimTools.Frm_SimTools.MyMessageBox_ClickedButton(Boolean YesNo, _WhatToDo ButtonClicked, Int32 PluginIndex, String _FileName)
       at MyMessageBox.MyMessageBox.Yes_MouseClick(Object sender, MouseEventArgs e)
       at System.Windows.Forms.Control.OnMouseClick(MouseEventArgs e)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.8.4470.0 built by: NET48REL1LAST_C
    SimTools
        Assembly Version: 3.0.0.0
        Win32 Version: 3.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/SimTools.exe
    KGWYIaAhTfcCXDkvmAevILnTknXsA
        Assembly Version: 0.0.0.0
        Win32 Version: 4.8.4488.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Game_PluginAPI_v3
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Game_PluginAPI_v3.DLL
    Axis_PluginAPI_v3
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Axis_PluginAPI_v3.DLL
    Interface_PluginAPI_v3
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Interface_PluginAPI_v3.DLL
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 14.8.4084.0 built by: NET48REL1
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System.Core
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    MyVibeButtons
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyVibeButtons.DLL
    MyTuningButtons
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningButtons.DLL
    System.Configuration
        Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        Win32 Version: 4.8.4084.0 built by: NET48REL1
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    AddonAPI_v3
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/AddonAPI_v3.DLL
    Default_AxisPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/AxisPlugins/Default_AxisPlugin.dll
    Generic2DStandard_AxisPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/AxisPlugins/junk1.remove
    MyCheckBox
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCheckBox.DLL
    MyButton
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyButton.DLL
    MyFilterButton
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFilterButton.DLL
    Default_InterfacePlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/InterfacePlugins/Default_InterfacePlugin.dll
    AMC_InterfacePlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/InterfacePlugins/junk1.remove
    VirtualOutputAPI_v3
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/VirtualOutputAPI_v3.DLL
    Default_VirtualPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/VirtualPlugins/Default_VirtualPlugin.dll
    GameDash_PluginAPI_v3
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/GameDash_PluginAPI_v3.DLL
    Default_GameDashPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/Dash/Plugins/Default_GameDashPlugin.dll
    CSCore
        Assembly Version: 1.2.1.2
        Win32 Version:
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/CSCore.DLL
    MyLoadButton
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyLoadButton.DLL
    MyOneClick
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOneClick.DLL
    MyRadioButton
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRadioButton.DLL
    MyTextBox
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox.DLL
    MyDropBox
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDropBox.DLL
    MyTextBox_MinMax
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox_MinMax.DLL
    MyDashControl
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDashControl.DLL
    MyPicMenu
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPicMenu.DLL
    MyScrollBar
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyScrollBar.DLL
    MyExport
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyExport.DLL
    MyProfileComboBox
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyProfileComboBox.DLL
    MyRepoInstall
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoInstall.DLL
    MyRepoButton
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoButton.DLL
    MyUpDown
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyUpDown.DLL
    MyAxisLimiting
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyAxisLimiting.DLL
    MyNotifyMarker
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNotifyMarker.DLL
    MyTuningScrollBar
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningScrollBar.DLL
    MyMessageBox
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMessageBox.DLL
    MyTextPrompt
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextPrompt.DLL
    MyParkingLocation
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyParkingLocation.DLL
    MyPatchingNotes
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPatchingNotes.DLL
    MyBannerStopButton
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyBannerStopButton.DLL
    MySaveButton
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MySaveButton.DLL
    MyOnOffSlider
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOnOffSlider.DLL
    MyDatePicker
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDatePicker.DLL
    MyRegBox
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRegBox.DLL
    MyTopMenu
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTopMenu.DLL
    MyMainMenu
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMainMenu.DLL
    MyFolderBrowser
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFolderBrowser.DLL
    System.Management
        Win32 Version: 4.8.4435.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    System.IO.Compression.FileSystem
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
    System.Web
        Win32 Version: 4.8.4465.0 built by: NET48REL1LAST_B
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    PresentationFramework
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    WindowsBase
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationCore
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
    System.Xaml
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
    Network_GameDashPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/Dash/Plugins/Network_GameDashPlugin.dll
    Serial_GameDashPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/Dash/Plugins/Serial_GameDashPlugin.dll
    Virtual_GameDashPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/Dash/Plugins/Virtual_GameDashPlugin.dll
    Sliders_VirtualPlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/VirtualPlugins/junk1.remove
    MyTrackBar
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTrackBar.DLL
    LiveforSpeed_GamePlugin
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/GamePlugins/junk1.remove
    AssettoCorsa_GamePlugin
        Assembly Version: 2.0.7.0
        Win32 Version: 2.0.7.0
        CodeBase: file:///C:/Users/Dgibs/AppData/Local/SimTools3/GamePlugins/junk2.remove
    enabled.
    For example:
    <configuration>
    </configuration>
  11. yobuddy
    50,831Coins
    @Historiker,
    Did you initiate the update, or was it set to auto update game plugins?
    Just need a know where to look is all.
    We have had to alter the api a bit as we can finish off the game api and get examples out.
    So that may be the cause also.
    I believe the api is finished thou, and should not cause errors again (if that's what caused it).
  12. Historiker
    9,208Coins
    I started the update.
  13. noorbeast
    151,706Coins
    +11,045 / 56 / -2
  14. yobuddy
    50,831Coins
    Update Pushed!
    Fixed Game Update Index Error.
    Added auto restart after a game dll update so it references the correct version of the plugin.
    (As it still uses the one in memory - it will take some work to get around it.)
    (For now thou, this fixes the error.)
  15. yobuddy
    50,831Coins
    Thanks guy's!
    Took me a minute to find this one!
  16. yobuddy
    50,831Coins
    Anyone have Project Cars 3 for a test?
    If it runs, please look at the dash inputs and tell me if Dash Outputs Extra 1 (should be called 'CarName') is actually the vehicle being used.
    Plugin requires in game settings.
    And here is the test plugin...
    ProjectCars3_GamePlugin.zip
  17. yobuddy
    50,831Coins
    Assetto Corsa Competizione posted to the repo. :thumbs
    Let me know if you have any problems.
  18. Tim Palmgren
    IT Recruiter
    82Coins
    Hey @yobuddy had a busy patch but Easter weekend is coming up so should have time to dive in again. Would this PC3 plugin be compatible with the same UDP settings as PCars 2 and AMS2? I don't have 3 but I do have PC2/AMS2 which I can test?
  19. yobuddy
    50,831Coins
    Good idea, I can get a PC2 version done for the weekend.
    I have been working on crash detection, and believe I need to move the the plugins internal crash var from the status outputs (checked every 150ms) to the motion outputs (live data), so the crash detection can fire a bit faster. It's stinks as I have to update all the plugins one last time (I hope lol), but it's a better way to do it in the end.
    Hope to get the needed change done today.
  20. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    Hi @yobuddy I've just started using a 10" tablet as a second monitor to view simtools when in game but simtools window is just a tiny bit to big is it possible to make the window so it can be resized?
Thread Status:
