3dof Proyect Racing
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by David1982, Apr 5, 2022.
  1. David1982
    David1982 New Member
    Mecanico
    España
    63Coins
    Hi friends !!!
    Greetings from Navarra, Spain
    I'm still starting in this world... Although I've been looking at simulators for many years, but I've been told that it can be done in moderate humidity.
    But there is a problem, the more I read the more doubts I have! I have knowledge of real car mechanics and home electricity, but electronics I am completely null.
    After reading a lot and watching hundreds of videos, I really know what I want...
    A DOF3 loss of traction car racing simulator based on rear wheels,
    specifically something similar to this in the structure and type of driving, I'm in love
    This similar estructure: https://opensimracing.com/products/super-sport-motion-rig-25-series-plans?variant=28421719425
    I am going to make the base in heavy steel, very stable and resistant, and the seat platform in aluminum
    to lighten weight and that the motors suffer as little as possible,
    I weigh 65kg, but I need power and sensation,
    I want to race in rally and circuit racing
    I have no space problems
    I don't even know where to start... First I want to start with the "mechanics", select type of motors, power supplies etc, but I don't know what items I need!!
    Could you help me select the necessary parts?
    I would appreciate it from the heart
    I promise to upload photos, videos and manufacturing information of the entire process
    I don't want to buy twice... That's why I want to buy three powerful motors from the beginning,
    with an independent power supply for each motor
    I want to start with the motors I have read a lot but I still have more doubts: Dc 24V 400W 50:1, Wheelchair motor etc.. I dont know... Any link aliexpress o ebay please??I've been searching for days and I'm totally lost...
    Thank you very much in advance mates!!!!
    152,177Coins
    +11,063 / 56 / -2
    That is @Avenga76's rig, the build thread is here: https://www.xsimulator.net/community/threads/my-3-dof-seat-mover-gs-4-simvibe.5596/
    Many of us started in the same position, with a dream and lots to learn.
    Before buying anything spend some time researching and understanding design Vs physics and what is required to drive a rig, SimCalc can help get your head around that: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    Check out the FAQs, in particular see the SimTools, fundamentals of motion and the design sections: http://www.xsimulator.net/community/faq/
    You can go through existing member projects for specific ideas or inspiration: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    Or search for specific types of projects using the Google Custom Search function on the Recent page: https://www.xsimulator.net/community/find-new/posts?recent=1
    Most wheelchair motors are purchased second hand of the likes of Ebay, they are likely a bit of overkill spec wise for this particular design, but a good choice cost wise if you can get them at a bargain price.
    Good luck with your project.
  3. David1982
    Mecanico
    España
    63Coins
    @noorbeast
    Thank you very much for answering!!
    After reading a lot of post
    I have already decided on these motors:
    https://es.aliexpress.com/item/32902109090.html?spm=a2g0s.9042311.0.0.2e1463c0TU9sLS
    250W
    24W
    4200rmp
    120rmp
    40:1
    24Nm
    or
    250W
    24V
    3000rpm
    120Rpm
    25:1
    20 Nm
    What do you think Master?
    I hope to see decided well!!
    I have no idea what else I need :)
    The design is with thrust on the shoulders and loss of traction.
    I have also bought my first driving set, it is already ordered, it is a fanatec kit
    CSL DD 8Nm
    Pedals V3
    Thanks!!
    152,177Coins
    +11,063 / 56 / -2
  5. David1982
    Mecanico
    España
    63Coins
    I will update this message with the entire manufacturing process and cost (12/4/2022)
    Well, finally this morning I went shopping to build my DOF Nebuchadnezzar :)
    He hasn't decided on the motors yet...or anything electronic, I hope to carry out the project with everyone's help!
    But for now I have work to start.
    I went to the junkyard to buy candy:[​IMG][​IMG]
    Cardan 8€
    Ball joints 2€
    Old circular saw blade (to make CTN arms) is good and strong steel
    4mm steel squares x4 7€
    3mm aluminum sheets x5 12€
    Connectors (Amazon) 13€
    arms 16mm x6 4€
    35mm steel shaft for loss of traction 2€
    Steel bars and Steel plate ( Traction loss) 5mm 141€
    50x50x2 mm Base Structure
    40x30x2 mm Platform lost traction and steering wheel and pedals
    40x20x2mm Seat structure
    Little by little I will collect the rest of the necessary pieces
