SimTools v3 Alpha (Questions, Answers, Fixes, Show & Tell)
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Mar 17, 2022.
Thread Status:
Not open for further replies.
  1. llluis
    Quebec
    1,632Coins
    Is RPM the only GameVibe effect available in iRacing plugin?
  2. yobuddy
    51,535Coins
    Yes, for right now anyway.
    But I will go back and deck it out later.
  3. yobuddy
    51,535Coins
    oops, boundary probably does that also.
    I'll fit er fixed.
    It's just how it gets displayed, should show a 1 is all.
  4. yobuddy
    51,535Coins
    There is not really any room to display anything but the 5 or 6 chars that are there.
    And they are named directly above anyway...
  5. yobuddy
    51,535Coins
    Interface naming is on the list, as the names can also be used for sim re-setup.
    Chat soon!
  6. Tim Palmgren
    Tim Palmgren Maker / Motion Fanatic
    IT Recruiter
    Auckland, New Zealand
    82Coins
    3DOF, Motion platform, 4DOF
    @yobuddy if you can get the deadzone / boundary sorted and give me a bit more headroom on the filter (instead of 50% of 2.x make it 75%) then I should have everything I need to get cracking on profiles. (not sure if you saw the request for even more smoothing amongst the other replies).
  7. llluis
    Quebec
    1,632Coins
    Just to be sure what I was mentioning:
    Those 2 lines are "duplicated", but with different labels.
    I was suggesting making the second equal the first.
    I didn't understand the "5 or 6 charts" you mentionned.
  8. llluis
    Quebec
    1,632Coins
  9. yobuddy
    51,535Coins
    I understand, but the bottom one has less room because of the button.
    Top one has 2 rows for text, bottom one has one row because the buttons in the way.
    We could move the button, but I'm not sure were yet.
  10. yobuddy
    51,535Coins
    The display value is wrong for deadzone and boundary, but they should work just fine.
    I think we may have proven that the old range for smoothing was not so bad.
    I think I'm just going to restore it to what it used to be, as people know what to expect with the old values.
    Chat Soon!
  11. yobuddy
    51,535Coins
    New Axis Standard plugin uploaded. :thumbs
    I believe all filters are now adjusted to work correctly.
  12. Tim Palmgren
    IT Recruiter
    82Coins
    THanks @yobuddy I agree with you, it means also I can just port the old values across which is useful. Sorry for the trouble!
  13. yobuddy
    51,535Coins
    No trouble at all buddy!
    Tuning stuff in can be a bit of work.
    Thanks for the help!
  14. llluis
    Quebec
    1,632Coins
    Did you publish it to the SimTools repo? I didn't get any update and I'm still needing to use massive amount of smoothing.
  15. yobuddy
    51,535Coins
    Depends on your settings in the options if you will get the update, but I posted it.
  16. llluis
    Quebec
    1,632Coins
    All options on auto.
    Any way to confirm the plugin version installed?
  17. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    I see a bug in Test Settings, when centering the Axis by clicking on Stop Testing some do not center and the program hangs for 20 or 30 seconds. I put here the link to a quick video made with the mobile where you can see what I say.
  18. early_m
    early_m Active Member
    Chelmsford
    839Coins
    +1 for this. A version number in the corner of the thumbnail?
  19. yobuddy
    51,535Coins
    If you goto the repo, and point to the upper-left of the banner of the standard axis plugin, it will open its data page, and you can check your version.
    • Dislike Dislike x 1
  20. yobuddy
    51,535Coins
    Interface testing fixed! :thumbs
    Update Pushed!
Thread Status:
