Resolved Sim hub, UDP telemetry and Richard burns sygnal muffed
Discussion in 'SimTools DIY Version' started by Krzysztof Dej, Apr 4, 2022.
  1. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Hi I have problem with simhub port forwarding. Due to long term testing and adding more simtools stuff I have noticed that I have my rbr configured in 4124 port but sim tools use 4123 and when I try set tuning center maybe this was reason why rbr not work properly. And then my problems starts again. Can't set simhub to work with sim tools. When I set in game port to 4123 and set udp relay in simhub to 6776. Simhub doesn't work. But when I set in game port to 6776 and in simhub to 6776. Sim tools working but simhub doesn't!!!! Maybe some port issue? When don't start simtools simhub work. Someone have multiple devices in rbr using udp and simhub?
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Have you used port forwarding?
  3. Krzysztof Dej
    Poland
    1,100Coins
    This in game port 4123 in simhub like this but there is an error this 4124 means 4123 :p
  4. zapata_h
    España
    308Coins
    You have reviewed the configuration manual, it seems to be correct
  5. Krzysztof Dej
    Poland
    1,100Coins
    For me the same. Maybe some compatibility issues or administrator rights. I will try in the evening and give the feedback. But for me it's something strange all the time with Richard burns rally. Like something Suppress the signal. Once it's working once working like 20 % sygnal
  6. yobuddy
    51,372Coins
    I wrote a little test udp relay app.
    It's nothing fancy at all, but seems to be working here just fine.
    Set the game to send to the test app (port 5123 - default), then configure the UDP Relay app to send copies anywhere you want.
    Not sure if it will fix your problem, but you are free to give it a shot.
    Take care,
  7. Krzysztof Dej
    Poland
    1,100Coins
    First i wanna thank you for your time and work. Now I solved this. Sim hub problem. After reinstalled everything working fine. The best thing was that all others game was working normal, only rbr not. Now it's working without any configuration :)
    On pics : game config, simhub config
  8. Krzysztof Dej
    Poland
    1,100Coins
    Not solved at all. Something crazy is happening. Yesterday when I testing those problem I run rbr from launcher and play replay becouse lack of time and don't want to seat and try stage all the time after changing settings in sim hub. In replay all telemetry works so I play replay, check is my bassherker via simhub works and is my gseat via simtools works. When reinstall simhub everything start working but.... On the replay. Today I start playing stage and sygnal to my motion rig is like muffed but on replay working like a charm. Wow why. Is replay sent different sygnal or playing online make rbr sygnal doesn't working properly? Is any way to check sygnal? Is the same like from rep?
  9. yobuddy
    51,372Coins
    My guess is simhub is editing the ini file automatically?
  10. Krzysztof Dej
    Poland
    1,100Coins
    I try play without simhub and was the same muffed? What ini file? Rbr config file?
  11. yobuddy
    51,372Coins
    Sorry man, i just posted in the wrong spot.
    I was referring to the port number changing by itself.
    Are you using version v1.02?
    As this plugin works with RBR_SSE v1.02 only.
    SimTools only uses the data It's sent, so I don't know why it would be muffled in online play but works with replay.
  12. Krzysztof Dej
    Poland
    1,100Coins
    Yes I use this one but in rsf hungarian plugin. Is your udp tool will show any issue with data send? Or differences between data from game and reply?
    What I will try :
    Another rbr with Czech plugin (offline, online, reply)
    Single player game (original game but for me I only play in multi but can show is online plugin make error)
  13. yobuddy
    51,372Coins
    Nope
    It just re-sends the packets it gets to places.
  14. Krzysztof Dej
    Poland
    1,100Coins
    I have info from hungarian plugin that replay don't even sent udp telemetry so it's strange. Is it possible to contact Richard burns rally plugin creator?
    153,039Coins
    +11,116 / 56 / -2
    What do you mean by 'hungarian plugin' is that a mod?
  16. Krzysztof Dej
    Poland
    1,100Coins
    Rbr(Richard burns rally) is still alive becouse of community. Rbr itself don't have multiplayer options. First people from Czech create platform to create rallys. It's online plugin where u can drive and your result is online and someone else can run his rally and all results will be online page. Those rally is about one week and when it's end results r official. Czech plugin is very old and not updated. Now hungarian community create own plugin that all people migrate to. This plugin have its one launcher that u can easily start. Becouse it's known true that rbr i not easy to start ( all maps mods and plugins)
    But it's working on patch 1.02 and launching with rbr_se. Exe file like on simtools plugin requires
  17. Krzysztof Dej
    Poland
    1,100Coins
    SOLVED DEFINITELY!!!!!
    FOR ALL PLUGINS (Pro, rsf)
    In ini file or launcher DON'T NEED to set 4123 port. Game don't sent Ngp telemetry to simtools. It use its own sygnal from 4123 port so if u use UDP telemetry send it will be conflict or sygnal muffed
    It's crazy but after year of play I start playing rbr correctly now!!!!
    I put this to rbr section for all who have problem also ( I have few messeges)
  18. bruno1210
    bruno1210 schumi06
    103Coins
    I agree with you the updates are great on the other hand with simtools effects not terrible compared to dirt rally 2
  19. Juah
    Juah New Member
    - 133Coins
    Hello everyone I am looking for a guide to configure simtools with rbr and a 3 dof, which I am using with all driving sims, opening the tuning center no data arrives thanks to those who help me
    153,039Coins
    +11,116 / 56 / -2
    RBR has just been added to the Beta SimTools v3, and confirmed working, so I would suggest that: https://www.xsimulator.net/community/threads/simtools-v3-public-beta.17329/page-10#post-232659
    Keep in mind v3 is still in Beta, does not support all games yet, and is open to have members find bugs, but it can be run on the same PC as v2, so you can have the best of both worlds.
    Do update SimTools v2 to the latest version before installing Beta v3: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
