Dimensions of a 2DOF motion platform for SimCalc
Discussion in 'DIY Motion Simulator Projects' started by imajavaid, Nov 16, 2021.
  1. imajavaid
    imajavaid Member
    169Coins
    Yes I have tested upon the default profile and its still not working
    152,700Coins
    +11,091 / 56 / -2
    If SMC3 is properly configured, and Interface Settings are correct, then something is interfering with communications. Make sure SMC3 utility is not running at the same time as SimTools.
    If that is not the issue then likely your firewall/antivirus are the culprits. Temporarily disable both, restart everything and re-test Output Testing.
  3. imajavaid
    imajavaid Member
    169Coins
    Still facing this issue . The motor is producing the humming sound
    Firewall is off though
    152,700Coins
    +11,091 / 56 / -2
    Putting aside SimTools and SMC3 for a moment, does that motor make that sound in either direction when power is applied to it?
  5. imajavaid
    imajavaid Member
    169Coins
    No. when I moved this motor by applying power supply using smc3 it doesn't produce that sound
  6. imajavaid
    imajavaid Member
    169Coins
    Issue resolved. I was using range of 0%on my axis assignement . I increased it to 100% and my motors start moving
  7. imajavaid
    imajavaid Member
    169Coins
    I saved game list as x-plane on axis assignment and then moved on output testing. as I returned back to axis assignment my game is automatically changed to default. Why is this so ?
    152,700Coins
    +11,091 / 56 / -2
    Axis Testing uses the Default profile, it is not driven by any other profile, hence why it returns to the Default profile.
  9. imajavaid
    imajavaid Member
    169Coins
    The virtual axis of output setting is not working as I patched the game. I have set data ouptut settings and i have patched the game . But dont know whats going wrong
  10. imajavaid
    imajavaid Member
    169Coins
    these are profile editor settings
    152,700Coins
    +11,091 / 56 / -2
    Try port 4123:
  12. imajavaid
    imajavaid Member
    169Coins
    Port 4123 worked
  13. imajavaid
    imajavaid Member
    169Coins
    Now I got my virtual axis moving. But when I turn my motors on they dont roll and pitch. What the issue now :(
    152,700Coins
    +11,091 / 56 / -2
    Does the rig move as expected in Output Testing using the Default profile and fully loaded with yourself?
  15. imajavaid
    imajavaid Member
    169Coins
    yes the rig moves as expected in the output testing. Soon I will share its video. Does profile editor has to do something with this error
  16. noorbeast
    152,700Coins
    +11,091 / 56 / -2
    Leave the Profile Editor at default for now.
    Does the rig move as expected with LFS?
  17. imajavaid
    imajavaid Member
    169Coins
    Are these settings correct?
  18. imajavaid
    imajavaid Member
    169Coins
    Not with LFS. I patched Xplane and test in on output testing. It moves correctly
    152,700Coins
    +11,091 / 56 / -2
    Please post pictures of all of your Xplane settings, including Axis Assignments and Tuning Center while Xplane is running.
  20. imajavaid
    imajavaid Member
    169Coins
