6dof project with low cost wiper motors and 24V IBT-2
Discussion in 'DIY Motion Simulator Projects' started by SteULM, Jan 12, 2022.
  1. SteULM
    SteULM Active Member
    600Coins
    And while very artisanal and a bit ugly, it served its purpose ....
  2. SteULM
    600Coins
  3. SteULM
    600Coins
    After the various cuts of the boards I presented all the components to see the result (I should learn to make drawings first ... :grin)
  4. SteULM
    600Coins
    Now I am waiting for the paint to dry completely and then I start the assembly ....
  5. SteULM
    600Coins
    Motor assembly and electronic test ...
  6. SteULM
    600Coins
    Assembly completed, now I fix the cables a little bit and connect to Simtools so I have a run ...
  7. SteULM
    600Coins
    Finally solved the engine overheating problem !!!! After about two hours of testing on the track, the engines are cold !!
    With this configuration you are finally having fun. hug::cheers
    150,950Coins
    +11,025 / 56 / -2
    You certainly have been busy with the redesign, nice work :thumbs
    When the dust settles and you have a bit of time it would be great to see a video of your rig in action.
  9. SteULM
    600Coins
    Of course, I call my trusted tester and I do ....
    However, I have a problem that I cannot understand, one of the 3 Arduino boards is constantly disconnected, always the same, it loses the USB data for an instant but it is enough to stop the two connected axes. Has this happened to someone before ... ??
  10. SteULM
    600Coins
    It got stuck even while I was making the video I had to post so I tried to lower "Intensity level" in "Profile Editor" from 100 to 80 and it doesn't freeze anymore ... as if too high signal peaks give problems to the card!
  11. SteULM
    600Coins
    Anyway here is the video of the test :thumbs
  12. SteULM
    600Coins
    I confirm what was written before by doing other further tests, lowering "Intensity Level" in "Game Manager" I no longer had USB signal interruptions. Hope it will be of help to anyone with this kind of problem!
  13. noorbeast
    150,950Coins
    +11,025 / 56 / -2
  14. SteULM
    600Coins
    Thanks noorbeast, the arduinos 3 are on a controller that only houses them so I think it's optimal.
  15. SteULM
    600Coins
    Here is a picture of the USB controllers
  16. noorbeast
    150,950Coins
    +11,025 / 56 / -2
    That looks pretty good and USB2 is actually more robust than USB3. Are you using quality USB cables and Ferrite Magnets to limit interference?
    While lowering the Intensity Level a bit, like 3-5 degrees, should make a difference, down to 80% is a lot and adds a lot of global smoothing, so I would suggest further investigation and experimentation.
  17. SteULM
    600Coins
    As usual you are a source of knowledge, a reference for all ... Thanks my friend !! :thumbs:cheers
  18. SteULM
    600Coins
    The cables I think are good, they are Amazon Basics protected against interference, the ferrite cores I have ordered and tomorrow they will arrive and now I have disabled the "Selective Suspend" of Windows and I try if it has improved the thing.
  19. SteULM
    600Coins
    I confirm that the problem is exclusively of USB (thanks again noorbeast that you directed me) in fact by connecting the card that always disconnected in a HUB controller different from the other two the problem no longer occurs, however different USB disconnections continue to be discovered. Let's see tomorrow when the ferrite clips arrive how it goes.
  20. seuszok
    Poland
    465Coins
    Did You conect all power suplys and arduinos grouds?
    I supose You use 16u2 arduino drivers board if they are ch340 pls change it.
    Regards
