Question SMC3 doesnt communicate with board
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Rodeo5150, Feb 28, 2022.
  1. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    20220226_133419.jpg 20220226_133344.jpg Yeah I plug everything in I get lights going get power supplies humming and all that done can I get no action out of the rig. when I when I turn it on it says can't connect to board retry abort or ignore that message.if I hit ignore it will open up the smc3 and let me to change stuff but I get no action out of the Board or Motors.
    I'm wondering if I got the wrong encoders cuz im using some cheap little crappy ones that I found around the house 10K ones that I took out of like a soldering station while I'm waiting on my hall effect sensor. Cuz I am confident overwhelmingly confident that I have everything wired and connected right I made sure of that I took a week designing building and plugging in wires and designing air flow. So I'm confident my motion boxes built right
    152,177Coins
    +11,063 / 56 / -2
    If you wiggle the pots by hand does the line move in SMC3?
  3. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    No absolutely nothing happens it's gets no no no communication whatsoever I'm wondering when I upload the smc-3 to my Arduino there on, comm 8 and 9 okay and even my device manager says they're on a eight and nine but when I look at the code in the Arduino it says is 0 and 1 or mayb another 0 i forget but def not 8 and 9. should I have changed ? that do I have to change the comm in the sketch in order for it to read right?
    152,177Coins
    +11,063 / 56 / -2
    Is your Arduino IDE set to the correct com port in its settings?
  5. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Well that's what I'm asking you I don't know like I said, in the IDE sketch after compile and upload it says, 0 + 1 in the sketch but when I compiled and uploaded it the ide under com port it said comms 8 and 9
    152,177Coins
    +11,063 / 56 / -2
    See the Arduino guide re setting Board and port: https://docs.arduino.cc/learn/starting-guide/the-arduino-software-ide
  7. Rodeo5150
    1,251Coins
    Arduino, 6DOF
  8. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Hey @noorbeast I only uploaded the SMC3.ino on my arduino but I noticed there is a SMC3Utilities.ino that was downloaded at the time I downloaded the SMC3. Was I suppose to upload that SMC3Utilities.ino to the Arduino also?
    152,177Coins
    +11,063 / 56 / -2
    SMC3 is the code for the Arduino, bottom of the first post: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    SMC3 Ultilies is a handy Windows app to configure SMC3 settings for the Arduino, bottom of the second post: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
  10. Rodeo5150
    1,251Coins
    Arduino, 6DOF
  11. WILLIAM DEITZ
    WILLIAM DEITZ New Member
    - 24Coins
    DC motor
    I'm having this same problem. Did you ever get this resolved?
    152,177Coins
    +11,063 / 56 / -2
    Can you please post pictures of your SMC3 settings, hardware used and confirm the Com Port is correctly set in the Arduino IDE and SMC3.
