  1. Tom1980
    Tom1980 The Sky Is The Limite
    Business Management
    Alabama, USA
    26Coins
    The the other issue is that I only get 4 volts from the ground and signal and it never changes no matter which way I turn the dial. I always thought that when I turn the dial I should either get 5 volts or nothing but that just isn't the case
  2. Gadget999
    12,156Coins
    are both pots the same ?
  3. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Yes they are. I got an oscilloscope coming in hopes that will help me test further. I wonder if the whole issue is the Mega board since the coding was written for the uno which I have on the way also. What are your thoughts?
  4. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Good evening folks, does anyone know why SMC3 wont engage my motors. The feedback line is centered and the power to the motor is on. Any help would be appreciated. I did test the motor and the bridge as well as all the connection in a different program that I wrote and they all work ok just not with the program written on here. I am sure that I am missing something here, any ideas.
  5. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I adjusted the PWMmax to 255 and still no movement
  6. Volvox
    Volvox New Member
    Ukraine
    1Coins
    DC motor, Arduino, 4DOF
    Good afternoon. I ran into a problem with platform axis shaking and non-linearity running simtoosl. At the same time, in the SMC3 program, the platform axes behave perfectly. The potentiometer wires are shielded and grounded. Hall sensors also tried to use, the result is the same. The settings of the dead zones, the limits of the eye also do not give results.
    I have attached a video demonstrating the problem.
    (sorry for my english, I use google translate)
  7. Volvox
    Volvox New Member
    Ukraine
    1Coins
    I ended up having a common problem with language settings https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    After installing English instead of Russian, everything began to work just perfectly and control the axes correctly.
  8. Gadget999
    12,156Coins
    it would appear both your pots are dead
    can you get hold of a normal pot that is not hall sensor type to test the board
    (its not likely the mega is faulty - the smc3 code should work on an uno nano etc
    make sure you have the correct type of motor driver enabled in the sketch)
  9. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Good evening, interestingly, I ended up using B1oK pots which are pennies on the dollar compared to these and they worked. My next issue is that the motors wont engage. If its not one thing it another you know. I have also written my own code to test the bridge and the other components and they have also came back ok.
  10. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Is there anyone that can give me some advice please. What would be the reasoning for smc3 utilities not engaging the motor even when all the specs are within parameters.
  11. Gadget999
    12,156Coins
    If you move the pots does the green line move up and down ?
  12. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Yes it does.
  13. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I have tested the hardware and everything is ok. I am in mode2 running a mega for now. I have 24 volt motors from a wheel chair.
  14. Gadget999
    12,156Coins
    good stuff :)
  15. Volvox
    Volvox New Member
    Ukraine
    1Coins
    What changes to make to smc3 to get rid of this nasty sound? The platform works well, but this sound is very annoying.
    I use motors from a windshield wiper.
  16. miaziol
    miaziol Member
    Poland
    - 60Coins
    Elo
    I have a question. Is this normal behavior? When lifting or lowering, the lever does not stop in the position marked in the program, but goes beyond the actual range of motion to the end and returns to the set position after a while. This is normal behavior or I need to change something in the sketch and upload it to the arduino again.
    153,920Coins
    +11,156 / 57 / -2
    Please post this video and picture of all of your setting on your build thread, as a range of factors may be involved, including design issues.
  18. Volvox
    Volvox New Member
    Ukraine
    1Coins
    As I understand it, no one has the same sound from motors?
  19. Steve B
    Steve B Member
    248Coins
    I have similar sounds from the motors on the rig I'm currently building, I think SMC3 in mode2 is not correctly controlling IBT-2 H-bridges.
    Working on a way to drive IBT-2 using mode1, may be a few days to see if I'm successfull.
  20. Volvox
    Volvox New Member
    Ukraine
    1Coins
    Good evening. Let me know when there is a result. And then this sound annoys me a lot, it is louder than my t300.
