6dof project with low cost wiper motors and 24V IBT-2
Discussion in 'DIY Motion Simulator Projects' started by SteULM, Jan 12, 2022.
  1. SteULM
    SteULM Active Member
    600Coins
    Finished the welding phase of the base
  2. SteULM
    600Coins
    Given the first painting with an anti-rust primer on the base and motor plates, tomorrow I'll move on to painting.
  3. RacingMat
    21,059Coins
    Good project!
    Try to improve your welding skills ;)
    it's really advised to grind the welds: you can check if it's really fused (you may be surprised! it's often not really fused. The bumps we see are not a good omen.)
    And it's more beautiful.
  4. SteULM
    600Coins
    :grin:grin:grin
    Hi Racingmat, I thought I couldn't even do it, it's my first time with the welding machine. Let's hope it holds up ...
  5. SteULM
    600Coins
    However with the hammer I beat the welds once finished following the tutorials and it seems to hold.
  6. SteULM
    600Coins
    Tomorrow I put on a first coat of paint and once it is dry I try to mount the plates with the motors
  7. SteULM
    600Coins
    Now I am calculating the dimensions of the upper base in the CAD to see how I can insert the seat with the accessories
  8. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    148Coins
    Hey Steulm. I look forward to hearing how this works for you. How did you decide on 40mm/60mm levers? Is that what your 2dof used?
    Project is looking great so far!
  9. SteULM
    600Coins
    Hi Keith thanks, you are the same levers. They have two positions at 50mm and 70mm from the motor shaft.
  10. SteULM
    600Coins
    Today I prepared everything after the painting, tomorrow I start the assembly.
  11. SteULM
    600Coins
    Today I started assembling the parts, let's see where I arrive ...
  12. SteULM
    600Coins
    Completed the assembly of the motors
  13. Keith
    Keith Active Member
    Electrician
    148Coins
    Looking good. You made the rods? Did you just weld a nut to each end of the pipe?
  14. SteULM
    600Coins
    Yes, I wanted to try and it seems that I have succeeded
  15. SteULM
    600Coins
    Here, I finished assembling everything, I cut a piece of plywood to test if everything works and then I will decide how to obtain the upper platform
  16. Keith
    Keith Active Member
    Electrician
    148Coins
    You work fast. Have you tested it yet?
  17. SteULM
    600Coins
    Yes, I connected everything and calibrated the motors with SMC3. I'm finishing the setup on Simtools but today and tomorrow I have to wire an ethernet network in a studio so I'm still.
  18. Chris_Beeves
    2,097Coins
    Awesome build!
    Is there any specific reason why you want the connecting rods that long? I'd try to keep them as short as possible for stability.
  19. SteULM
    600Coins
    Yes Chris thank you, once mounted I realized that 500mm is too much ...
    As soon as possible I try to change to 350/400mm.
  20. Chris_Beeves
    2,097Coins
    Cool! Out of curiosity, why not less? Is that the minimum?
