My very cheap 2dof
Discussion in 'DIY Motion Simulator Projects' started by SteULM, Dec 15, 2021.
  1. SteULM
    SteULM Active Member
    600Coins
    You use SMC3 for motor pid calibration, this setup varies according to the motors, drivers and power supply you use. I will place mine with these motors and 24V power supply.
  2. SteULM
    600Coins
    Regarding the assignments of the axes, here too the values vary according to what one wants to receive as a response to the reaction of the motors according to the feeling one wants to have. For now I am using this configuration on RBR that I use for more time with which I am very comfortable.
  3. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    439Coins
    thank you for sharing! I'll try your settings, hope it can give me a clearer image on how this simtools works.
    good luck with your new 6dof project!
  4. SteULM
    600Coins
    I hope they can help you in case you ask, if I can I am happy to help you.
    • Friendly Friendly x 2
  5. RP39
    RP39 New Member
    42Coins
    Great build! Would you be willing to share some more infos on the motors?
  6. SteULM
    600Coins
    Thank you. Within the limits of my knowledge I am available.
    PS.
    I do not see your origin in your contact, I would like to know what nationality my interlocutors are.
    Thank you.
  7. SteULM
    600Coins
    The characteristics of the motors are:
    12-24 V 25/50W MAX NM 150 15-70 RPM
  8. RP39
    RP39 New Member
    42Coins
    Thanks! May I also ask where you got them from and how much you paid?
    I found these ones. Do you think they are sufficient (strong/fast enough) for a similar build?
    https://www.ibs-gruppe.de/shop/deta...MI0IKv_MGx9QIVgqrVCh19gAMBEAQYAiABEgKdJvD_BwE
    I simply don't know, where to put this kind of information. There is no option in the user control panel... (at least I don't find it).
  9. RP39
    RP39 New Member
    42Coins
    I'm from Germany, Bavaria.
  10. SteULM
    600Coins
    I can't tell you anything about those motors, I can tell you that the ones I'm using do their job, they cost little and, what I think is very important, they have brass gears and not plastic. You can find them here -> link sito
  11. SteULM
    600Coins
    For the origin you have to click on your contact at the top right and choose "Personal Details", you will find them under "Location".
  12. SteULM
    600Coins
    Of course, they are not engines like you see them on many projects but, in my opinion, better than common wiper motors. Then it always depends on what you want to achieve, I am satisfied with a simple structure and considerably low costs, you see
  13. RP39
    RP39 New Member
    42Coins
    Those are indeed nice and not expensive. Are you using the same motors for your new 6 DoF build?
  14. SteULM
    600Coins
    Yes, they are the same.
