Bug Need to keep restarting Simtools for it to connect and enable motion
Discussion in 'SimTools DIY Version' started by Tino.Sturlic, Dec 15, 2021.
  1. Tino.Sturlic
    Tino.Sturlic Member Gold Contributor
    209Coins
  2. Thanos
    Electronics Engineer
    2,854Coins
    Can you check if the RESET_EN trace is cut?
    Apart from that, can you try on another computer? Or do a clean reinstall of the windows? And select US language for locale language settings...
  3. Tino.Sturlic
    209Coins
    Just tried with second interface I have. It detects it differently.
    But the same problem occurs.
  4. Thanos
    2,854Coins
    Yeah, most likely windows issue. My advice, reinstall windows, use only the games and trusted software and don't install antivirus. Use that PC only for your gaming and not for surfing the web so there is not a chance to catch malware or spyware...
  5. Tino.Sturlic
    209Coins
  6. Thanos
    2,854Coins
    Yes, the bottom board is the same... check the RESET_EN on it... just pull it apart carefully.
  7. Tino.Sturlic
    209Coins
    If I might ask what will that do? Can you explain?
  8. Tino.Sturlic
    209Coins
    It's already cut. I checked with multimeter.
  9. luu trung
    luu trung Member
    172Coins
    Hello. I use only 1 USB cable from the computer to 8 USB ports with power supply. I use all 8 ports for peripheral devices. Does this affect the USB bandwidth? Sometimes while I'm playing, "Game Engine SimTool" is turned off.
    152,021Coins
    +11,061 / 56 / -2
