Taro's sim - What think about this design?
Discussion in 'DIY Motion Simulator Projects' started by taro28, Mar 1, 2010.
  1. taro28
    taro28 New Member
    3Coins
    I'm a guy from Spain. I've been reading a lot about the forum projects and I want to build my own simulator.
    My first design consists on a 2 DOF simulator moved by wiper motors. I'll like to move everything to get good immersion into the game: the driver seat, wheel, pedals and the screen.
    A cause of my really bad English language, i think that is better put some pics of my actual designs :D
    This design shows the general idea of the project, the basis will be changed below. Note that the planes isn't at scale and may be varies a lot.
    For the basis I'll use this other most common configuration:
    I had thought to put the projector just under the seat, close by the pivot motion to minimize the movement of it.
    The image will reflect over two mirrors and will project on the front screen.
    First i'll want to build only the mechanical issue of the simulator, without the projector and screen, but with space reserving for put it after.
    I think that maybe the wiper motors haven't power enough for move all. It could put various wiper motors at parallel (it's possible?).
    Other thing, for the structure i'll planned to use aluminum profile for decrease the inertia. Someone who has worked with it could tell me if with this material with a thickness of 30mm is sufficient for stand the pedals and steering wheel? or it should be have 45mm?
    Again, i'm sorry for bad english writing, i'm learning for improve it. :blush:
    Greetings
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    I like the concept, but I'm not sure how much vibration a projector bulb can withstand and if the vibration will reduce the life of the bulb. Anyone have any data on this?
  3. Frakk
    Frakk Active Member
    328Coins
    I think you should put the projector above the head. It might move, but you will need a counterweight anyways. I don't know how those mirrors will effect your image with that huge curved screen, but it will complicate things for sure.
    The life of the bulb will depend on the type of bulb and the amount of vibration. The filament in some bulbs can break easily and vibration is sure not going to help.
  4. taro28
    taro28 New Member
    3Coins
    HI, thanks for replies.
    I thought on that, I cannot found anything. If I'm not wrong, the lcd projectors uses a gas discharge lamp and it haven't any filament inside it. http://en.wikipedia.org/wiki/Gas-discha ... nstruction
    By the other hand, the force dynamics simulator uses a normal projector, a Hitachi CP-X260 according to his website.
    http://www.projectorcentral.com/Hitachi-CP-X260.htm Don't seems anything special. But this does not say that it don't lose service life. I should seek more information.
    Greetings
  5. Frakk
    Frakk Active Member
    328Coins
    If you get a projector with one of those lamps it should be fine. I have only taken apart an older projector and it had a halogen lamp in it.
