I need help on SMC3
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by SteULM, Dec 6, 2021.
  1. SteULM
    SteULM Active Member
    600Coins
    As the title suggests, I have a problem with the motor calibration on SMC3. Following the tutorial to the letter but the green cursor of the potentiometer cannot be brought to the center, trying to bring the blue target up everything works by moving it to manual but the limits cannot be calibrated.
    150,986Coins
    +11,025 / 56 / -2
    Just to be clear with the un-powered motors in their neutral mid position you should be able to remove the pot, turn it by hand until its line is mid graph in SMC3, then carefully reteach the pot.
  3. SteULM
    600Coins
    Hi noorbeast thanks for the immediate answer, in this picture you can see the maximum excursion of the potentiometer, I can not bring it to the center
  4. SteULM
    600Coins
    The potentiometer is a normal 10K it is not multiturn but I don't think that's the reason ....
  5. SteULM
    600Coins
    As you can see from the first image, with the motors powered, by moving the cursor manually the motor behaves correctly by reversing the rotation, only that the limits cannot be adjusted to those values so far away and there is a risk of breaking the potentiometer that I am leaving not tightened.
    150,986Coins
    +11,025 / 56 / -2
    Additionally your Max limit is set to zero.
    Clip Input is very low.
    Clip Input Used to create a band at either limit of the target range beyond which any values sent to the SMC3 are clipped. In addition to this clipping, if the motor feedback does move beyond this range (typically through inertia), the SMC3 will attempt to brake the motors hard by driving them in reverse until they are back out of this limit zone. The value can be anything from 0-255 (however can’t be less than the current limit setting). Reverse braking is applied in the band between the Clip Input and the Max Limit settings. Reverse braking can be disabled - refer to PWMrev.
  7. SteULM
    600Coins
    Sorry........
    I had to set those values to get the feedback travel inside the limits, if you look at the last image setting the limits correctly the potentiometer excursion stays out and the motors don't turn
  8. SteULM
    600Coins
    I tried to replace the potentiometers with others of different values and I also tried to do the tests on two other PCs but with the same results ...
    Please help me. :(
  9. Gadget999
    11,983Coins
    measure the actual resitance of the pot in the up and down postion
    is the feed to the potentiometer 3.3v or 5v or more ?
  10. SteULM
    600Coins
    Thanks for your interest, they both measure 9.9k max and 0k min powered at 5V, but I've also tried others with different resistances and they always give the same result, the green feedback line is always shifted upwards as seen in the images above .
  11. Gadget999
    11,983Coins
    what type of board are you using ? is it 5v compliant ?
    what is the voltage on the board ?
  12. SteULM
    600Coins
    I use Arduino Uno and the potentiometers are connected on pin 5V
  13. Gadget999
    11,983Coins
    swap the feed to the potentiometers to 3.3v and let us know what happens
  14. SteULM
    600Coins
    Unexpected error ....
    the negative pin from arduino has been disconnected !!
    Now the feedback is back in the center, thanks everyone for the help, I will update as we continue with the works.
  15. yaksnip
    yaksnip New Member
    - 47Coins
    hi need some help green will not follow the the blue i believe i have wiring rite. thank you
  16. SteULM
    600Coins
    but if you move the potentiometer by hand, the green line moves ...?
  17. yaksnip
    yaksnip New Member
    - 47Coins
    yes they do
  18. noorbeast
    150,986Coins
    +11,025 / 56 / -2
    And are the posts physically attached to the motors via a coupling?
  19. yaksnip
    yaksnip New Member
    - 47Coins
  20. SteULM
    600Coins
    you are sure you have wired everything correctly.
    Could you post some pictures of the wiring
