value1
Wreckfest Plugin 2.0.1.3
Simtools game plugin for Wreckfest 32bit
  1. DarkHunter82
    DarkHunter82 New Member
    96Coins
    Hello i have tried the joystick plugin. the game is enjoyble . i have configurate it with my wheel. i play it....the game is cool now . the simulator works well, but unfortunately lack collisions,the traction loss and the slopes of the track.
  2. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,509Coins
    I managed to get some form of telemetry from Wreckfest (any 32bit version) using a program called Spacemonkey mentioned by @Moe Colontonio . My hack wasn't pulling telemetry in quite the correct fashion, but it seems to be a good start. For anyone wanting to look at this and actually do it properly, what I did was:
    Download spacemonkey from Github
    Copy the spacemonkey exe and rename the copy DirtRally2.exe
    Run this as administrator
    Change the UDP output to port 4123 in Spacemonkey
    Start a Wreckfest race and get to the final screen before actually clicking/pressing a button to start the race
    Clicking on wreckfest in Spacemonkey and clicking initialise
    Wait for the game to be scanned and all the telemetry data to show up
    Voila - You rig will now go beserk
    It doesn't work as intended (and be warned my rig started walking itself across the room!) but it seems fairly convincing that with the correct settings and perhaps a dedicated Spacemonkey plugin, we might be able to get telemetry data from Wreckfest once more.
  3. Hocky
    Hocky Member Gold Contributor
    128Coins
    I have very quickly done a Beta plugin for SpaceMonkey as mentioned above.
    Only tested on my rig and on Wreckfest so be careful testing it and on other games.
    Updated the pdf and added a filtering file. The SpaceMonkey Wreckfest filters was like driving on clouds.
    The file added removes the filters and now add maybe some smoothing in Simtools instead.
  4. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    156Coins
    2DOF, 3DOF, JRK
    Thanks for this plugin. Mostly working on my Sim, although I'm finding it hard to make a profile that accurately provides forces when you collide. Is Extra1 Traction Loss or something else?
  5. Brett
    Brett Member
    Engineer
    156Coins
    2DOF, 3DOF, JRK
    Oh, a tip for new users. Make sure you unpatch the Wreckfest plugin before patching with Hocky's SpaceMonkey plugin. Simtools will crash otherwise.
  6. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    anyones knows how to run this plugin on 64 bit version?
    my 32 bits stay on black screen and dont works ( yes, i choose 32bits via steam )
  7. paulopsx2
    brasil
    647Coins
    So, i try all these things, cheat engine, etc... but i dont understand how to.
    Make a video or something for teach this crazy pointers ! tks
    153,890Coins
    +11,154 / 57 / -2
  9. noddyier
    noddyier New Member Gold Contributor
    - 384Coins
    It work well on my Motion , I take a lot of time to find these plugin (for non programmer like me )
    i think it should be benefit if you post as a Spacemonkey Plugin ? for simtools ? (i use it with VtolVR it take me a while to reach these post )
    Thank you for your work !!
  10. sci666
    1,210Coins
    does it work yet ? wreckfest is on sale on steam till 24th. ;D this plus VR would be awesome
  11. paulopsx2
    brasil
    647Coins
    dont works
  12. MatteKarla
    MatteKarla Member Gold Contributor
    20Coins
    Am I the only one that just loves Wreckfest?
    I'm working on a SimTools3-plugin and a custom Wreckfest telemetry application with code from SpaceMonkey. My plans are to get it to detect Wreckfest running automatically, and automatically scan memory when a new map loads. It will only work automatically in single player mode.
    It's working, but I have a lot of code cleanup to do and need to fix the process detection (now you need to start Wreckfest first and then WreckfestReader. Map loading/exiting detection is done.
  13. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    You are absolutely NOT alone in loving Wreckfest.
    If you are indeed able to create a working and somewhat simple to use plugin, I think that the community would be overwhelmingly happy and re-visit the game with a new found interest.
    Single player is still awesome, and to be honest from what I've played online I actually tend to PREFER it in single player.
    Most of the time, online is filled with mindless animals...ANIMALS I tell ya...LOL!!!!!
    Cheers!
  14. MatteKarla
    20Coins
    I think I have a version that is good enough for general consumption, would anyone like to beta-test it?
    Since Wreckfest is such a violent game the "Profile intensity" slider needs to be set really low, I'm running at 15%. Is it something that can be auto set in plugin settings, or is there another solution?
  15. sci666
    1,210Coins
    wats the current state ? spacemonkey does some telemetry in the logscreen, looks also very good ....
    can simtools grab it or not ?
    spacemonkey plugin is startet ..but only on "connected" not "Game running" so nooo movement
  16. MatteKarla
    20Coins
    You can get it to work in SimTools2 if you use Hocky's plugin and space monkey with the defaultPacket format. But it's rather cumbersome.
    I'm working on a SimTools3 plugin that auto detects the player id, with that you can also play multiplayer. Currently it's a separate telemetry application (like SpaceMonkey) based on code from spacemonkey and a SimTools3 plugin that uses the telemetry.
  17. sci666
    1,210Coins
    But starting spacemonkey does not trigger simtools in my case.... It stays on "connected" not "game running"
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Would be happy to test it :thumbs
  19. MatteKarla
    20Coins
    Awesome! Sent you a PM with instructions.
    Have added a couple of features not available in SpaceMonkey and Hockys ST2-plugin.
    • Detects game running.
    • Automatically detects and attaches to send telemetry when you start a new race.
    • Works with multiplayer (by figuring out your name the telemetry provider can figure out what index you have and load telemetry for the correct player).
    • Also sends "basic telemetry" to SimHub when using buttkickers (udp port 20777, in format CodeMasters Extra Data 3, use Dirt2 for example)
  20. MatteKarla
    20Coins
    It's really sad that they don't support VR, but you can get 'fake-VR',
    It's awesome! I have a Quest2 and it works best for me with the steam version of Virtual Desktop. the Quest-version is a lot blurrier and has some delays.
