prilad
Richard Burns Rally (SSE) plugin 2.0.0.0
SimTools game plugin for Richard Burns Rally (SSE version)
  1. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,058Coins
    Ok. If u can send me i try. Tnx for help by the way :)
  2. Bulletpup
    Bulletpup New Member Gold Contributor
    117Coins
    You're welcome!
    To be clear what motion rig are you using? I only have 2 actuators so I don't use all the telemetry but you can adjust things to your rig.
  3. Krzysztof Dej
    Poland
    1,058Coins
    I have 2dof motors in the back
  4. Bulletpup
    117Coins
    So you are using a seat mover that allows side to side and front to back directions of movement, no yaw? If that's the case we should have similar usage of the telemetry.
  5. Octavio Hernández
    Octavio Hernández New Member
    - 1Coins
    Motion platform
    Hello, I am new here, I need help, I have the njmotion s, and the movement does not work when playing RBRPro, I run the game through RBRpro, can you help me ...
  6. Krzysztof Dej
    Poland
    1,058Coins
    Maybe pro discord or Facebook group? Maybe try launch rbr sse from main directory not from launcher
  7. Octavio Hernández
    - 1Coins
    Motion platform
    Hi, I was looking for a good setup for the RBR, for the Tuning Center and the percentages of the Axis, thanks if you can send me screenshots. Thank you.
  8. arcelivez2
    arcelivez2 Arthur
    145Coins
    3DOF, SCN6
    Hello, does this plugin work with RBR Pro? I've set it up, SimVibe/SimCommander works fine, but I can't get SimTools to work.
    It shows as patched and it doesn't complain when removing the patch or repatching it again - shows all successful. It also indicates "Game Running" when RBR Pro is running.
    Somehow there's zero telemetry output in the tuning center and no motion... I don't understand it. It used to work fine without RBR Pro as much as I remember...
    Can you at least tell what plugin files have to be put where in the RBR folder exactly and with what name? Maybe then I would be able to correct the patch manually just like I had to correct for RF2 once...
  9. Bulletpup
    117Coins
    What routing numbers are you using? Yes it works in pro with simtools.
  10. arcelivez2
    arcelivez2 Arthur
    145Coins
    3DOF, SCN6
    I have enabled the telemetry router in the contents and I have the following options active there:
    I have no idea what the ports are supposed to be - these are the default ones by RBRPro
  11. Krzysztof Dej
    Poland
    1,058Coins
    Try to change port 6777 to 4123 or manually in Richardbirnsrally. Ini and try launch from RichardbirnsrallySSE. Exe
  12. Bulletpup
    117Coins
    I'll see if I can remember to take pics of my ports and such.
  13. Octavio Hernández
    - 1Coins
    Motion platform
    You must run the sim tools as administrator for it to work for you in RBR PRO ...
  14. arcelivez2
    arcelivez2 Arthur
    145Coins
    3DOF, SCN6
    Thank you very much guys. As for the ports I am not so sure what helped. I added 4123 instead of 6777 in the RPR Pro Telemetry Router 2nd NGP compatible system section and applied. In the .ini file I only see:
    udpTelemetryAddress=127.0.0.1
    udpTelemetryPort=6775
    and no matter what I set in the telemetry router or if I modify this file manually, it always reverts to 6775 in the ini file.
    Any way at some point it started working after everything, but with very low output (my calibration was from 2 years ago for normal RBR, not Pro), I recalibrated and it was working well. But the next time motion didn't work again...
    So Ocatvio's reply helped on the last part at least, after starting SimTools Game Manager as an administrator it now seemed to consistently work.
    I'll keep testing if all stays like that, but thank you very much everybody for your support and I do hope that this summary will somewhat help anybody encountering issues with RBR Pro similar to mine.
  15. Krzysztof Dej
    Poland
    1,058Coins
    My pov view
  16. Krzysztof Dej
    Poland
    1,058Coins
    Hi I have problem with simhub port forwarding. Due to long term testing and adding more simtools stuff I have noticed that I have my rbr configured in 4124 port but sim tools use 4123 and when I try set tuning center maybe this was reason why rbr not work properly. And then my problems starts again. Can't set simhub to work with sim tools. When I set in game port to 4123 and set udp relay in simhub to 6776. Simhub doesn't work. But when I set in game port to 6776 and in simhub to 6776. Sim tools working but simhub doesn't!!!! Maybe some port issue? When don't start simtools simhub work. Someone have multiple devices in rbr using udp and simhub?
  17. Krzysztof Dej
    Poland
    1,058Coins
  18. vin100lorant
    vin100lorant New Member Gold Contributor
    Professeur Electrotechnique
    Beynes
    191Coins
    Hello !
    Is it exist a possibility to get vibe on rbr?
    Thanks a lot for your help !
  19. Krzysztof Dej
    Poland
    1,058Coins
    Vibe is some king of shaking? Yes show me your port config, and what rbr launcher r u use?
  20. arcelivez
    arcelivez New Member
    95Coins
    3DOF, SCN6
    Yes, SimVibe works grear with RBR normal and RBRPro - I have used it with both. I just don't remember if there's anything special to do, but I think it worked out if the box.
