Ralph's Racingsim Project
Discussion in 'DIY Motion Simulator Projects' started by ralphvdberg, Jan 26, 2010.
  1. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,790Coins
    Hoi Ralph.
    Het ziet er tegek uit.
    Ik zie dat je de neus van je 959 instelbaar hebt gemaakt met een stoel slede.
    Mooi gedaan
    gr. Ad
  2. ralphvdberg
    ralphvdberg New Member
    Racecar/Porsche mechanic
    Netherlands
    277Coins
    Dank je Ad, wat bedoel je met 959?
    Moest wel iets verstelbaar maken anders wordt het zo lastig met lange mensen ;D
    Heb je zelf ook een simulator??
    Gr
  3. ralphvdberg
    Netherlands
    277Coins
    Will make some pic for you in the next days.. :yes:
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,790Coins
    Nee de simulator gaat nog even duren.
    Met je 959 doelde ik op de werkplaats (de dakar winaar uit tachtiger jaren)
    Gr. Ad
  5. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Thanks.
  6. ralphvdberg
    Netherlands
    277Coins
    Hi Guys..
    Back from holliday..
    And there was a supprise for me when I was coming home...I thought my scn5's.... but not the scn5's but a speed ticket.. on the time when i was going to Nima (Niels) to test his simulator.. Most expensive simulator ride of my life €610 (850 dollar) (64km/h to fast) :dollareyes:
    Still waiting for my scn5's.. they are since 8 Feb at the customs office.. :thbd:
    Now back on building....
    Do someone have a Logitech x540 surround set? I ordered a set but it is in backorder.. I want to know what the demensions are from the subwoofer without the standing legs.. want to make a frame for it..
    Thnks..
    Tommorrow i will make a pic for you mike.. :cheers:
  7. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Hi Ralph,
    Sorry to hear about your speeding ticket. That is wildly expensive!
    Regarding your shipment and the customs delay, something is very unusual. I have had other shipments clear the same customs facility in 1-3 days maximum. I would suggest that you contact the customs office to see if they require further information. A delay of this duration is not normal.
  8. ralphvdberg
    Netherlands
    277Coins
    Hi Bernard..
    Thnks for asking..
    I already did that.. the said that they could hold it max 30 days.. (till 8 march) I will wait.. you and I can't do something on it..
    I have a lot things to do on my sim.. I can wait al little longer :?
  9. ralphvdberg
    Netherlands
    277Coins
    Hi Mike..
    Finally the pic of the scn5 holder..
    Put a rubber in and outside.. I have some different rubbercompounts to test..
    Can also faster the nut to set the rubbers stiffer.. First need to test..
  10. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Nice work Ralph. That looks like it's going to workout really well.
    Thanks for sharing.
    ....Mike
  11. RaceRay
    Hamburg, Germany
    23,876Coins
    Hi Ralph,
    Nils told me few days ago about your ticket. Realy expensive, soory to hear that!
    It´s the best proof that driving for some hours in a realistic simulator can blur the feeling of speed :blush:
    Do you want to capsulate your actuators complete? When you do that, you should think about a cooling solution. After some hours of driving the actuators could become hot and shut down after a critical temperature.
    I am also interested if your SNC5 holder reduce the noise of the actuator. That yould be a big advantage! So keep us updated :cheers:
    Br
    René
  12. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi ralph,
    sorry for this.
    rene the ticket was i have say wars from the ralphs drive to me with only 20-25 to fast in germany.the big ticket is from ralphs drive after the sim driving in niederlands.after the sim ralph are many faster.
  13. ralphvdberg
    Netherlands
    277Coins
    No I don't capsulate the whole cilinder.. Only half.. I put some foam in the tube for the sound.. maybe it works...
    I'll keep you updated..
    Today I got a letter from the customers office.. the need the bill.. I will send it when i get it from bernard.. :D
  14. ralphvdberg
    Netherlands
    277Coins
    Update;
    Hi Guys,
    Here a update
    Put some brushed alu plates around it
    Replace the monitor mount for a nother one.
    Computer build in
    Floorplate with some carpet en a little door in the front for the computer.
    I think te next week will the scn5's will come.. (waiting now a month) :eek:
    Some special backgrounds for chris!! srry! :cheers:
  15. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Looking good Ralph :)
  16. bvillersjr
    Ohio, USA
    438Coins
    Hi Ralph,
    Looks good.
    Your customs office has had the package for 20 days now! Have they offered any explanation as to why? I have not been contacted by them. This is the first of many shipments that I have seen held in customs like this.
    I look forward to seeng your sim completed.
    :cheers:
  17. ralphvdberg
    Netherlands
    277Coins
    Yeah.. I know.. I already called them.. I send them the bill .. after they see it they have 1 week to deliver it..(that's till tuesday)
  18. RaceRay
    Hamburg, Germany
    23,876Coins
    Nice work...i would paint it in white ... with red stripes ... that fits perfect to the GT3 in the background :D
  19. CXCSimulations
    CXCSimulations Member
    - 9Coins
    I have to say, I'm a little concerned about the placement of the SCN5's on your design. They seem way too close to the pivot point. You'll get a lot of speed, but not enough power I think. You may be in danger of over stressing them.
    Have you considered using SCN6's instead? They might be much better suited to your design.
    Also, after looking at your holders for the SCN5's, you may run into trouble getting to the back 2 bolts at the top. Consider cutting large access holes (enough to get a hex wrench in) to ease installation.
    All together it's a great looking design. I definitely see some Motion Pro II design cues in there...... :)
  20. ralphvdberg
    Netherlands
    277Coins
    thanks for the tips, :cheers:
    If you are looking to Nima's (niels) his old sim the scn5's are standing al most 90 degrees.. I tested his sim.. It was working realry great.. First i wanna test my design with the scn5's...(I thinks this week they will come) I'am just 60kg, I think that will be good for the power.
    Let you know the test results..
    The Design is a little from your Motion pro 2 and a little form this forum and a little from myself.. :)
    How is your business going with the Motion pro 2?
