Racing 6DOF stewart platform
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Feb 15, 2019.
  1. Gadget999
    12,156Coins
    I weighed the 3 corners of the base
    The two rear corners were approx 65 kg each
    The front corner was approx 70kg
    Without me in it all corners were closer to 35 kg
    That is complete weight of the rig including the base, motors and arms
    Total unloaded 105kg
    Total loaded 200kg
    Conclusions:
    The rig is quite heavy and is of a strong industrial contruction
    The motors have quite a bit of power
    I am heavier than i thought !
    On the plus side the rig seems well balanced
    I looked at the tuning and the rear motors were doing quite a lot of work in surge, sway and roll
    I reduced the % and tested a powerful car on a fast circuit. The car had a lot of movement particually under braking and acceleration.
    The motors did not really get hot with temps between 25c and 35c
    Regardless I will implement a cooling solution to allow endurance racing
  2. ryanosman
    ryanosman New Member
    Commercial Recreational Sim Owner/Operator
    Western Canada
    272Coins
    3DOF, DC motor, AC motor, Arduino, Motion platform, 6DOF
    Your motors are 400 watts ea and you have commented that they are plenty powerful... I've sort of gathered that a reasonable plan is about 100 watts per motor... what do you think?
  3. Gadget999
    12,156Coins
    100 w will not be powerful enough
    my motors are 400w but my gearbox is only 25:1 so they are working quite hard and after a while get hot
    since last week I have upgraded to double motors so each arm has 800w
    it does not make acceleration faster but each motor is now doing half the work and is cooler
  4. ryanosman
    Western Canada
    272Coins
    It would be a big help for me if you could share the model / source ( / price)
  5. Gadget999
    12,156Coins
    they are made by Parvalux - used for many purposes often used for wheelchair and winches
    around £300 each iirc
    pick a wheelchair that has decent motors and buy them 2 at a time when they crop up
  6. Gadget999
    12,156Coins
    • Disagree Disagree x 1
  7. Gadget999
    12,156Coins
    made some progress on the sim today - i now have 2 x 400w motors per dof
    so each motor is effectively 800w
    i have joined the end of the motors together where there was a brake flange and the original motor still is connected to the 25:1 gearbox
    i found after extended testing the motors were getting hot and installed a powerful aquarium air pump that pumped air into the motors
    now with the twin motors I am seeing about 35C
    the original DC motor drivers are now driving 2 motors instead of one and do it with ease
    Today we added a VR headset
    I went for a FOVE VR headset -- https://www.getfove.com/
    2560 X 1440 DISPLAY
    42% more pixels than other PC VR HMDs
    it has eye tracking so you can see where the driver it looking and it can also be used to interact with games by following your gaze etc
    So far i have only tested it with RF2 but it is quite impressive - the screen area seems quite large and I like the way you can adjust your focus to look at the dash and then again out through the windscreen
    So far I am very pleased with the Fove it seems to have good performance
  8. Gadget999
    12,156Coins
    video of the sim here
    Yesterday I was lucky to have a real racing driver try out the sim
    We were using a logitech wheel and he had some praise and some criticism
    The turn rate of the wheel did not seem to match a real car
    The brake pedal was not repsonding as a real car
    However the motion on the sim did feel like a real car and he was able to use the feedback to adjust his driving.
    He wanted to make changes to the car setup and see how the car felt
    The track was RF2 brands hatch in a btcc ford focus he wanted to change the rear bump from 12 to 8
    Immediately the car changed and he was able to push it harder and he felt the feedback enabled him to feel the limits of grip.
    He felt it was the best simulator he had ever driven and attributed it to the movements being very fast and in sync with the real physics as they happened in real time
    Some of the sims he had tried previously were damped and smoothed resulting in a different less precise feeling.
    I was beaming from ear to ear that the sim was doing a proper job, and feeling very proud of what we have achieved.
    I have a Thanos DD wheel on order and have built a set of hydraulic pedals to go with it so I am hoping the wheel and pedals will match the motion in terms of fidelity
    :cheers
    Thank you xsimulator for all the help and support
    • Like Like x 7
    • Winner Winner x 3
  9. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    hi bro, great build, i use 2x ibt-2 for one motor to give enough power, i ordered 1x 100a driver like you use, but i didnt found anywgere how to wire it could you help me how to wire it by diagram or some photo?
  10. Gadget999
    12,156Coins
    you can see the wiring diagram attached
    basically 5v and gnd
    a1 / a2 - direction for M1
    b1 / b2 direction for M2
    pwm motor1
    pwm motor 2
  11. absyfadhel1
    bahrain
    556Coins
    thanks for help bro, but you have any photo for your connection? real photo? becuase i'm lost with wiring to arduino , sorry its my problem
  12. Gadget999
    12,156Coins
    how you wire it depends on which arduino sketch you are using
    if you are using smc3 - the diagram will be on that thread
    you may need to create you own build thread to get help
  13. absyfadhel1
    bahrain
    556Coins
    i have my own thread but no one answer so i message you, i use smc3 but i dont know how to wire the board to arduino exactly
  14. Gadget999
    12,156Coins
    The wiring diagram is on the first page of the smc3 thread
  15. absyfadhel1
    bahrain
    556Coins
    yes i know but its for ibt-2 and MM not 100a? sorry for annoying
  16. Stefan4DOF
    Stefan4DOF New Member Gold Contributor
    Engineer
    Denmark
    180Coins
    DC motor, Arduino, 4DOF
    hi Gadget999
    Very nice build you have, and it is a good thread.
    How did you make the rods?
    they look like aluminium pipes, and then somehow you have mounted a nut in each end.
    they look lite and durable.
  17. Gadget999
    12,156Coins
    Yes they are ally tubes with a thick wall thickness, the ends are drilled and tapped to take m18 rod ends and a locknut is fitted. There are stronger than they need to be. You could use a smaller diameter rod or kart track rod
  18. man05ru
    man05ru New Member
    53Coins
    2DOF, 6DOF
    Lay out your settings in simtools (interface and axis)
  19. tadeusz
    tadeusz New Member
    34Coins
    HI GADGET999
    I SEE YOU HAVE USED THE AIR SPRINGS
    WHAT STRONG AND LENGTH YOU HAVE USED?
    HOW LONG IS ARM ON MOTOR?
    BEST REGARDS
    TADEK
  20. Gadget999
    12,156Coins
    The air springs are not in use any longer - they dampened the motion
    the arm length is approx 125 mm with 3 holes in it
    a more recent video is here
    • Like Like x 5
