First steps
Discussion in 'DIY Motion Simulator Projects' started by Kenshiro27, Apr 21, 2021.
  1. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Hello
    I will therefore present my simulator project to you and resume the first images of my first message from a new member.
    Do not hesitate to give me advice or constructive remarks because it will be my first achievement of this type. For the moment, I only have to realize an arcade machine and a pincab (virtual pinball machine).
    The first image found on the web really inspired me so I go over there by redrawing the model so that I can make it with the little material and tools at my disposal to get there.(I know ... I'm not ready to work at PIXAR)
    And the last image and the starting point of the project with the "chassis" of my futur simracing.
  2. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    construction is progressing slowly but surely
    here is a photo of the metal frame cladding recovered from an old diesel tank
  3. SeatTime
    All the best for your journey into motion simulation, just be mindful of the rigs final weight including yourself + peripherals. The sims motors and your hair will thank you.
  4. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Hello
    Only the seat and I will have movement on this simulator, the rest will be fixed. That said thank you for the advice
  5. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    A lot of work today for the realization of the mobile seat
    I picked up the idea for the rotating parts on this site, so many thanks to those who posted all of these great ideas.
  6. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Painting the front panel of the simulator
  7. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Oup'ss, I forgot the pictures
  8. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Manufacture of keys to connect the motors to the seat
  9. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Sorry for a handling error, that's what it's like to have a laptop on your lap.
  10. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I take the time off to wire the system, install the software and do the tests and it's a disaster. Nothing works. The computer part is the one I know the least about this project.
  11. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Can we test our installations without a game plugin? Or is there a "test plugin"? If a charitable soul would ask me about this it would be really nice
    153,914Coins
    +11,156 / 57 / -2
    Can you please give more details about what is not working and post pictures of all of your settings.
  13. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Wahhh:thumbs
    Really very impressive.
    Great work and what a finish, detail and care, thank you for sharing
    I will try to make a report with images to be more precise tomorrow. Thank you in any case for having answered my distress call
  14. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    my installation is carried out with a 75% kit from simukit.
    The sabertooth and arduino are wired as in the pictures.
    And the potentiometer in 0V and 5V at the ends and connect in the center to the arduino in A0 for motor 1 and A1 for motor 2
    I installed in the arduino: XPID_sabertooth2x32_120w
    I also installed on my computer
    SimTools GameEngine and
    SimTools GameManager
    I am there
    Already for the moment have I done the job well?
  15. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    You were right from the start
    So thank you for your great advice
    In fact, precisely I had glued the contacts of the arduino so that they did not unsolder
    But when you do this, you have to be careful not to accidentally touch one with an unused pole and then you can no longer see because the glue when cooling becomes opaque
    So I took it all off
    resolder cleanly and it does not work too badly in TURN OFF mode
  16. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I had a hard time and quite busy on the forum to answer many of my questions regarding the realization of the project. But that's it I finished my simulator. I therefore resume here the presentation of its realization
    painting of the different aesthetic elements of the simulator.
  17. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    also chassis painting.
  18. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Addition of resistors to relieve electronic motors
    And install the simulator in its destination room
    With the installation of his seat.
  19. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    And finally the installation of aesthetic parts and we get closer to the end of the initial design
    I wanted to install both forums as a sticker without which I could never have functionally completed this project XSIMULATOR and Noorbeast, and PCSHM and its creators.
  20. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    New
    I would allow myself 2 tips not being a specialist, to succeed in such a project or similar you need: The simtools manual at hand and read the FAQs of the xsimulator forum because 95% of the time the answer to your question is there.
    And again a big thank you to noorbeat for its availability and patience
