Ralph's Racingsim Project
Discussion in 'DIY Motion Simulator Projects' started by ralphvdberg, Jan 26, 2010.
  1. ralphvdberg
    ralphvdberg New Member
    Racecar/Porsche mechanic
    Netherlands
    277Coins
    Hi All,
    I started my Motionbase for the SCN5 actuators,
    First I started a pneumatic sim.. but I stoped with this project.. :roll: It was working fine.. but not realistic enough for my..
    I tested the sim from Nima (niels). 1 week ago... It's a very realistic feeling you have with the sim.... and i was sold :)
    Thanks Niels for your time and help!!
    I ordered 2 scn5 150mm from bernard... (SimXperience.com) Now I'am waiting :D
    I keep you posted..
    Thanks a lot for al the information on this forum!!
  2. sn4il
    sn4il New Member
    2Coins
    Very nice frame, congrats!
    You'll be fine with SCN5's but with Your space and equipment I would consider going hydraulic :D
    sn4il
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Looks very nice so far Ralph.
  4. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Great job so far Ralph :cheers:
  5. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Nice! another Dutchie with scn5's :D
    Veel succes met je project!
  6. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi ralph
    nice design.
  7. ralphvdberg
    Netherlands
    277Coins
    Thanks All!!
    This pic is for Niels.. he asked me on the phone how many degrees the scn5 stands..
    I have take the measurements form the drawing from the post 'building a proper....'
  8. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi ralph,
    you mast have 50 cm from under the seat to the top for the same seatmove
    were are have on my old sim with 100mm scn5
  9. ralphvdberg
    Netherlands
    277Coins
    Oke, also with a angle of 45 degrees and between the top unibolts 28.5 cm? (I will use the 150mm scn5!!)
  10. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    You demensions look good Ralph. I have about 58cm from the bottom of the seat to the top of the anchor point.
    ...Mike
  11. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    370Coins
    Maybe we should post those pictures with included measurements in the building proper motion base...., hmm ? We could start a collection of sim-setups with good/correct/proper dimensions. I will take a photo of my sim the next days, enter the dimensions and post it here as well. We could include the height of the main bearing in these posts - is this also important ?
  12. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi
    this is right.between the top unibolts the best is you can use the way between
    18 cm and 30 cm.you mast make a holder for this.if you have lower size you have more way for acculation in a curve.
  13. ralphvdberg
    Netherlands
    277Coins
    That's a good idea... I will post mine there if it's finished..
  14. ralphvdberg
    Netherlands
    277Coins
    I will lower the upper bar .. and make it adjustable..
    niels you are using the elastic straps.. Is that because you lower the actuator so much and on a very high angle?
  15. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    the elastic straps i have use a high angel and my weight is 110kg you have only 60 kg thats not a problem.
  16. ralphvdberg
    Netherlands
    277Coins
    Hi Guys..
    Here a some update pics...
    I Think this week my scn5 will delivered.. :D
    Put some 6 point seatbelt on.
    24 Full HD Screen..
    And some wheel to move the whole thing :happy:
    I think I will powdercoat the frame white and put some bordering of brushed aluminium on..
    and also a Logitech x540 surround set...
    Feel free to comment!! :cheers:
  17. Schnullerbacke
    Germany near Munich
    370Coins
    Hi Ralph,
    • Cool design !
    • Cool seat !
    • Very cool and wide belts (originally I wanted to get the same in red) !
    But - PLEASE - hide these cars the next time you're taking photos... That's not fair ;D !
    I'm looking forward to seeing more pics :thbup: !!!
  18. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Hi Ralph,
    Make sure you make provisions for some dampening in your design. The actuators are a lot quieter when you have dampening on them as the feel is also a lot more natural.
    ....Mike
  19. ralphvdberg
    Netherlands
    277Coins
    Thanks Mike.. I have already make the snc5 holder including the dampening..I'am able to replace them for softer or harder rubbers.. i read a lot and learning
  20. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Great Ralph,
    Can you share a pic of your scn5 holders? I'd like to see some other options for dampening the actuators.
