Marki 3DOF With Winch - Sabertooth 2X60
Discussion in 'DIY Motion Simulator Projects' started by Marki, Jan 13, 2021.
  1. Marki
    Marki Marki
    électromécanicien et Concepteur mécanique
    Montreal, Canada
    128Coins
    Hi All ,
    I work on a 3DOF For FlightSimulator, the principal utillity is for Condor 2,
    My Config,
    -3x Standard Winch 2000lbs 750W motor/1HP (153/1 planetary gears)
    -2x Sabertooth 2X60
    -2x Arduino Uno
    Specs;
    -12in Travel in Heave
    -Allow 45 deg in Pitch and roll
    Construction :
    -3D printing for positionning feedback parts (Yellow)
    -Laser cutting and CnC folding Sheets (Grey) After my built i will share the drawing and tuto to make yourself a command of lasercutting parts on a supplier)
    In Blue its a 3DScan of my seat and me , you can see my big nose :)
    See my Drawing image
    @Flymen
  2. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    Troubles,
    i succeeded to Connect The Ardruino and the sabertooth 2X60 on SMC3 with
    @BlazinH Tuto, i Use the SPS_8.2 Soft Start.
    I Resolve With @Flymen My first Trouble , To enable the connection on the Mover Output Serial , you have to close the SMC3 setup. i learn your com4 or others ports Cannot use with 2 application in same time :nerd
    Now im blocked to Connect the Ardruino and the sabertooth To Flypt Mover
    When i move the Simple Direct cursor , the Binary change at the bottom Output serial page , but the motor dont move?
    Im direct on Flypt mover , i dont pass with Simtool . This is the Trouble ?
    Many thanks
    @Pierre Lalancette
    @pmvcda
  3. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    @noorbeast , Need info with the last question ?
    Thanks !!
    Ps. I never received your post on my mail ( Alert ) here . I dont know why !
    153,830Coins
    +11,151 / 57 / -2
    I am sorry but I don't get what you mean, are you asking about @Marki's issue with FlyPT or an issue of your own?
  5. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    i explain my problem in video
    @Pierre Lalancette
    @pmvcda
    (P.s @Flymen you dont recieve the notification because my tread was blocked beacause i put a weblink to SPS tuto.)
  6. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    My trouble is Fixed ! All work, i test with condor 2 game .
    My trouble was, i fogot to put [ A < ] in output line [A<Axis1a>] .
    I thought I could click and drag the axes, and it would work like that, but we have to add[ A < ] to work
    Thanks to @Pierre Lalancette and @Flymen to help me! :):)
  7. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
    3DOF, DC motor, Arduino, 6DOF
    Glad it worked.
    I don't see any limit switch to your design. Is it something you thought about? It is quite important. I do not recommand to do any moving test without it, once the rig is assemble.
  8. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    @Pierre Lalancette
    Thanks for your recommendation.
    I'm curious to know How you have connected your limit switchs?
    I have planned a emergency stop with 200 Amp relay.
    Does your limit switch cut the main power or you have another alternative?
  9. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    Limit Switch Drawing Done
  10. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
    The way I do it is a closed circuit in all the switches (5 volts) that drives one relay. This relay drives 6 relays (12v) that let the power goes to the motors. If a switch is triggered, the circuit turns open, there's no more curent to any relay and all stop.
    That's my way.
  11. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    My Wiring Diagram
    (not tested)
  12. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Hi ,
    Your power supply switching is 24 v dc motor 12 v dc ?
    With your power supply 24vdc you can drop maybe at 18-19 v dc if you play with the potentiometer !
    Don’t forget the batterie 12 vdc on your wiring Diagram .
  13. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    My final and tested wiring for emergency
    @Flymen
  14. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    My project avancement
  15. RacingMat
    21,082Coins
    it looks good! like a LEM
    • Funny Funny x 3
  16. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    Assembly is finish!
    I had a terrible backlash as a problem, I fixed it by adding is elastic to keep the arm down and I widened the rodends in the top and centered my position
    Now , my problem is the power supply, i use truck 12v batterie and standard batterie charger (25 amp). but when the battery is in charge , it smells of sulfur. im not sure that good for health . i need to change my power supply . any suggestion for 3x 750w motor DC in 12v ?
  17. Marki
    Marki Marki
    Montreal, Canada
    128Coins
    Hi ,
    Here is the final result of my platform motion
    it largely exceeds my expectations, contrary to what I thought it is silent !! and respond well to the little jerk like the rough terrain when I take off or the bang when I land! that's great!!
    I fixed the backlash problem with 4 bolt here ,
    and for the battery I reduced the leveler of my winck from 8 "to 5" now to draw 10 Amps continuously on the 12v. this is very good and my 25amp car charger is more than enough
    i added Rudder pedals With arduino code
    https://www.ingeimaks.it/come-creare-una-pedaliera-joystick-con-arduino-uno/index.html
    I recommend this platform to all of you! I am impressed with his performance
  18. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
    Great set up. Small and compact, all the opposite of mine.
    Congratulation.
  19. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Nice Work !!!!
    I’m waiting your invitation to try this new toy .;):cheers
  20. Mauro Sebastian Panfili
    Mauro Sebastian Panfili Ruckus
    Venado Tuerto , Santa Fe , Argentina
    29Coins
    Hi Marki, I found your project looking for information on CONDOR SOARING SIMULATOR 2. I fell in love with it, congratulations! You have done a professional job! I am from Argentina and I have not found any builder who is fond of only flying racing cars. It would be an honor if you guide me to start my project. What type of motors do you recommend? I think it is the biggest investment in the project. Thanks for your time . Greetings!
