  1. noorbeast
    153,926Coins
    +11,156 / 57 / -2
    Not with SMC3, 3 max but better to use an MMs with just 2 motors for each MM.
  2. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    ready I understand .... there would be 2 motors for each MM interface1 motor1 and motor2 interface2 motor3 and motor4 CLEAR .... you don't need a SMC3 with 4 axis I understand I understand ... the only thing that would have to clarify is the com port of each arduino to the smc3 .... sorry, I'm a little tough, I didn't understand very well how I was going to configure the 4 motors. SORRY .... THANK YOU VERY MUCH FOR THE HELP
    153,926Coins
    +11,156 / 57 / -2
    Yes each Arduino will have its own com port, which can be found in Windows Device Manager.
  4. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Thank you very much sir for the stamina and the help of always thanks ..... it's a geñio.
  5. CaptBluescreen
    CaptBluescreen New Member
    131Coins
    Hi there,
    after a couple of years, I'm playing around with the old/new project I started with a friend in 2017 - When I'm starting Simtools Output testing, I see that the right motor is a little bit faster or the range of the right motor is a little bit larger than the left one. Is there an option where I can adjust the range of the second motor?
    153,926Coins
    +11,156 / 57 / -2
    Adjust in the SMC3 utility.
  7. LegendaryHotShot
    LegendaryHotShot New Member
    28Coins
    hello my motor does not move with SimTool, but SMC3 does move normally
  8. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    You would have to put a couple of photos to see if you put the parameters in the gameengine ... and also write in English so that everyone can help you.
  9. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Hello good people. Can someone explain to me how I do to save what I have loaded in an arduino uno ... I want to save what I have loaded in this arduino because I was using it for the simulator telemetry ... and now I want to load the SMC3 code and then when I buy the other arduino one I reload what I want to save today
    153,926Coins
    +11,156 / 57 / -2
    A super easy way is to simply save a screen shot of your SMC3 settings.
  11. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    One question I am about to test the 4 motors ... but at the moment I want to assign the com port to interface2, the com port 5 does not appear, which is the one that marks the second arduino. com 3 is engine 1 and 2 and com 5 is engine 3 and 4 but in interfaces 1 and 2 it gives me only com 3 port .... because it will be. I already have it fully configured with the smc3. There I could fix it ... it was to restart the machine just ... another question I have movement in the interface1 port com3 motor 1 and 2 and I have no movements in the interface2 com5 motor 3 and 4 these settings are fine. 20201128_203404.jpg 20201128_203345.jpg
    153,926Coins
    +11,156 / 57 / -2
    What are your corresponding Axis Assignments?
  13. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    these are the assignments I have axis assignments. 20201129_012840.jpg 20201129_012831.jpg
    153,926Coins
    +11,156 / 57 / -2
    You should not use (b) Axis Assignments.
    You only use the (a) Axis Assignments as you have here:
  15. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Hello sir, there is cancel the assignments b and leave the a ..... 20201129_113628.jpg but I still do not move .... in the smc3 engines 3 and 4 are perfect ... a question in interface2 are the parameters fine. 20201129_113700.jpg
    I put the interface - output of engine 1 and 2 [A <Axis1a>] [B <Axis2a>] in engine 3 and 4 and they work perfect, all 4 do not work together with these parameters INTERFACE1 [A <Axis1a>] [B < Axis2a>] AND INTERFACE2 [C <Axis3a>] [D <Axis4a>].
  16. noorbeast
    153,926Coins
    +11,156 / 57 / -2
    Double check the port is correct, as the rest of the Interface Settings looks OK.
  17. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Everything is as seen in the photos but I have no movements in axis 3 and axis 4 that would be the two in the back with the second arduino the MM and the 2 new motors 20201129_182546.jpg 20201129_182600.jpg 20201129_182616.jpg
  18. noorbeast
    153,926Coins
    +11,156 / 57 / -2
    The Tuning Center is not getting any data. Before messing with RF can you please verify Output Testing and in Live For Speed, as both are specifically for diagnostic and testing purposes.
  19. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    There I have been testing different configurations in the 1 and 2 interface and I could find the configuration that I think goes when I move arises in output testing the two forward motors are lowered when I brake and the rear motors are raised and when I move the motors 2 and 4 on the side sway Right they get up and those of the left 1 and 3 go down, the only thing I have to do is change the C and D of interface2, I was put on Aaxis1 Baxis2 Caxis3 Daxis4 and those of interface2 had no movement ... and now the axis1 and axis3 with A and axis2 and axis4 with B in conclusion, the configuration was like this Aaxis1 Baxis2 Aaxis3 Baxis4. 20201129_202943.jpg 20201129_202935.jpg
  20. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Sir, I ask you a question. I plan to buy another 12v 30a switching source for the other 2 motors, but the question is the source that I have is the bank for the 4 motors.?
