AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. pooh
    pooh Member
    584Coins
    OMG, it still doesn't work as expected and i learned it the hard way... estop was changed to hold position and when i pressed it it KILLED power to all servos and i went down :(
    i can't store correct settings now for that. if i "store" it - it shows "hold position" but then when i hit emergency button it kills power :( if i reset the controller it shows kill power again...
  2. pooh
    pooh Member
    584Coins
    ok, i think i know what the problem is and how to reproduce it:
    if you have force offline switch turned ON then it won't save settings (and there's no message "settings saved")
    i'm not sure if this is correct/expected behaviour but i will update it to 2.11fix4 again and check.
    i believe i should be able to change settings with force offline switched ON though...
  3. Thanos
    Electronics Engineer
    2,869Coins
    Load the latest firmware here:
    https://github.com/tronicgr/AMC-AAS.../enc_6dof_AMC_AASD15A_v2_11_beta_fix4_RGB.zip
    Then make sure to restore defaults by holding exit button as seen in this video:
    Then, make sure to have the Force Offline switch deactivated and set and store your settings.
    Thanos
  4. pooh
    pooh Member
    584Coins
    yes, force offline was the issue. is it intentional?
    btw, when using FO set to park the speed going down is ok but speed going up is not the one set in settings. it's the issue described in previous page.
  5. Thanos
    2,869Coins
    Yes, Just tested, everything saves correctly, and as I said you have to make sure to have the force offline switch deactivated.
    It doesn't save the parameters when force offline is active in purpose, as some were pausing the motion while still connected to the game, to do small adjustments, and there are lockup issues trying to save parameters in epprom memory while there are interrupts for incoming motion data. I just raise a flag that there are parameters waiting to be saved and wait normally for the incoming data to stop or the force offline switch to be deactivated and then it saves automatically...
    Thanos
  6. trev mac
    trev mac New Member
    hastings New zealand
    - 89Coins
    sorry to say yes I am as my rig is out in the shed which does not have any means of internet access to far away for wireless could I use the tp link but using its own wireless system? or if not what else can I use to eliminate this issue?
  7. Thanos
    2,869Coins
    Forget the powerline or wifi... just get 50m utp cable and run it to the shed...
    www.amazon.com/dp/B00BNKN24W/ref=cm_sw_r_cp_apa_fabc_2y3PFbY2YQZ8C
  8. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
  9. pooh
    pooh Member
    584Coins
    i recomend this shop as i have bought there. ver A and B differs by connection on servo side and you can choose whichever you prefer. 90 is size of motors and i went with 80 - servo flange is 80x80mm
  10. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    I Pooh thanks for your reply.
    Ver.A90 and Ver B.90 mean that the motor is 90ST-M02430? If yes as I'm looking for 80ST and not 90ST my choice should be only from "VersionA" or "VersionB" and I can exclude "Ver.A90" and "Ver.B90"? correct?
    Your choice was 80St "VersionA"'
    Thanks for support
  11. pooh
    pooh Member
    584Coins
    correct!
  12. pooh
    pooh Member
    584Coins
    Thanos, so now question remains about the momentary button connected in parallel with emergency button. what is expected behaviour of it?
    because i thought it should be possible to configure those buttons in a way that if my force offline switch is set to "hold position" then if i'm in the game and engage FO then it holds position and then i can push my momentary "park" button and it should go to park so i can exit the platform...
    at the moment it doesn't work for me if in game (connected to mover). the way i use it now is that my FO switch is set to "park" but that causes it to park even when i want FO for a brief moment at the begining of motion or in pitlane.
  13. Thanos
    2,869Coins
    The monetary button works only when the controller is offline, not receiving motion data at all. If its receiving motion data won't work even if you engage the force offline switch... I needed to enforce that to prevent issues with jumping to real motion data sometimes. The monetary button is used if you need to lift the platform powered, to place supports to work on it, like in racing cars in the pits... :p
    The Force offline switch behavior can be set to either move and stay at Standby (50%) or move the actuators to Park position.
    Thanos
  14. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    [QUOTE = "pooh, post: 208546, member: 2199"] corretto! [/ QUOTE]
    Perfect Thanks
  15. Olivier beaujoin
    Olivier beaujoin New Member
    France - Roquefort-les-Pins (06330)
    187Coins
    AC motor, 6DOF
    Hello Pooh,
    Thanks for your video and advise.
    I have tested your workaround using 'Force Offline' switch over my current firmware version v2.11 fix3 and unfortunately it does not work the same as with your firmware version.
    With v2.11, speed to go from parking to online/stdby is not the one I have configured (low speed) but still max speed.
    So as I think we should use latest firmware as much as possible (to benefit from evolution).
    I will ask again Thanos whether he could provide a video tutorial on "How to setup speed for parking to standby transition". This could help us to understand and potentially spot a bug in that area.
    Thanks again, Olivier
  16. Olivier beaujoin
    187Coins
    AC motor, 6DOF
    Hello @Thanos , Can you provide this video/tutorial ?
    This will help us to understand/configure standby speed properly.
    There could be as well potentially a bug in that functionality.
    Note: I Face as well similar speed issue with Manual button rate speed where the rate speed is applied when you press button (up/down/left/right) but is not applied when you release the button (full speed applied). This one is less critical as used only for initial test.
    Thanks, Olivier
  17. Thanos
    2,869Coins
  18. pooh
    pooh Member
    584Coins
    no, no, i can confirm that the speed set as for "going to standby position" doesn't work - no matter what i put there it uses it's speed (maybe it uses those washout speeds @Thanos ?)
    on the other hand, if i change "go to park position" speed - it works correct.
  19. Olivier beaujoin
    187Coins
    AC motor, 6DOF
    Hello @Thanos,
    Thanks for this video that I know already and that is more related to remote button/switchs led behavior (and that is well described in your documentation).
    I'm much more interested by video/tutorial on standby speed configuration and associated demo which I have not found anywhere for now.
    By the way, we can see on your video that the standby speed transition is much faster than the parking transition.
    Olivier
  20. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Hello @Thanos,
    I have the same problem as Olivier, when i release the manual control buttons (up/down/left/right), the motors return to their position at maximum speed, is there a parameter to adjust this return speed?
    Thanks,
    Eric
