Experimental DCS Plugin ready for testing
Discussion in 'Digital Combat Simulators (DCS)' started by Dirty, Jun 28, 2019.
  1. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
  2. Dirty
    All the way up front.
    7,949Coins
    Yes! Create the Hooks folder
    Or reinstall the plugin via Plugin Manager. It should create that folder for you.
  3. janio
    janio janio from brazil
    state employee
    belo horizonte
    184Coins
    thanks friends, you guys are great, i added sway, surge and extra 1 on ground, and the platform vibration on the runway during the takeoff route was wonderful. I'm trying the plugin without the euler angles to see which option gives me the most immersion.
    hugs.
  4. jpdesvals
    jpdesvals New Member Gold Contributor
    new-caledonia
    134Coins
    Hello every one ,
    firstable thanks Dirty for this plugin , feeling the ground bumps during taxi , take off and landing is sooo cool and was missing until now !!
    On my 6DOF rig i had to increase all the acceleration value as the original value ( *1 ) did not produce motion .
    A request : can you modify the Il2 BOS plugin so we can get the ground effect via the WOW like the DCS experimental plugin or is it undoable ?
    For the same reason that would be great , espetialy with warbird to feel the bumps during taxi , takeoff and landing .
    Sorry for my english ,
    Thanks again !
    Jp
  5. Dirty
    7,949Coins
    Great to hear that! :thumbs
    Have you set the max and min values in tuning center? Or are you only talking about the values while on ground? If only on ground, then yes, you can just change the factor in the script.
    No Idea. Does IL2 use a .lua script for data export? If so, it should be possible. Who made the plugin? I will take a look at it. Not sure though when I find the time for it.
    Cheers,... :)
  6. tadek
    tadek Active Member
    616Coins
    Hi
    I have a problem with the plug-in
    I have constant values all the time
    best regards
  7. Dirty
    7,949Coins
    Just for troubleshooting, go to "SavedGames/DCS/Scripts/Hooks" and check if you have the "DCS_Exp_Hook...." file in this folder.
    Then go to "SavedGames/DCS/Scripts" and see if there is an "Export.lua" file in there. If there is, try without that file and see if it does the trick.
    Then report back here with your findings ASAP :-D
  8. Icebeat
    Icebeat New Member
    - 61Coins
    I just want to thank you for this plug-in.
  9. tadek
    tadek Active Member
    616Coins
    Hi
    Still not working
    1.I delete "Export.lua" file in "SavedGames/DCS/Scripts"
    2."SavedGames/DCS/Scripts/Hooks" is empty
    best regards
    best regards
  10. Dirty
    7,949Coins
    Ok, there should be a file inside the Hooks folder.
    Make sure you have the latest plugin (v0.09) and patch DCS for motion as ususal. That should do it. :)
    If it works, restore the Export.lua file to "Scripts" and see if it still works.
    Let me know if it works.
  11. tadek
    tadek Active Member
    616Coins
    Hi
    I tries, with everything and nothing...
    I have a problem that I am using Sim Tools 2.0?
    Which version of Export.lua should I use for the DCS_GamePlugin.2.0.0.0 version?
    Best regards
  12. tadek
    tadek Active Member
    616Coins
    I have
    my game:
    "g:\Program Files\Eagle Dynamics\DCS World OpenBeta2\bin\DCS_updater.exe"
    folder save games in my language "zapisane gry":
    IP Seating (game menager) 127. 0.0.1
  13. tadek
    tadek Active Member
    616Coins
    I use for the DCS_GamePlugin.2.0.0.0 version, but after patched show v 0.09?
    Is it alright?
    Best regards
  14. Dirty
    7,949Coins
    I don't know, whether or not the version of SimTools makes a difference. I think SimTools is on version 2.4 but not sure. If you want to be sure, just install the latest.
    There are two plugins! If you are using mine, then in Game Manager you should see "DCS_Exp" and it looks like that's what you have :)
    There is the original Plugin, and that is on version 2.0.0.0 afaik.
    I have made a modified plugin and that is on version v0.9.
    So, the question is: Why don't you get any data?
    I have a suspicion! Could it be, that you have two versions if DCS installed? Openbeta and stable branch?
    Make sure that the version you are using has the Hooks folder with the Export-script.
    To check, go to "SavedGames" and check if there are two DCS folders: DCS and DCSopenbeta.
    Is that the case?
  15. tadek
    tadek Active Member
    616Coins
    I have original Plugin, DCS_GamePlugin.2.0.0.0
    but after instalation it show like on photo V 0.09
    is it right?
    maybe I should delete the temporary files in some folder related to the older plagin?
    best regards
  16. Dirty
    7,949Coins
    I guess you have two versions of DCS installed and/or you have not unpatched DCS through the other plugin.
    No worries, I am 100% sure we will figure this out.
    I will send you a PM.
  17. janio
    state employee
    belo horizonte
    184Coins
    dirty, I had the official dcs plugin, but I had to update the sim tools to 2.5, and came back with the plugin I used before, yours, so it doesn't receive telemetry from the dcs. this plugin is not for version 2.5 of sim tools?
  18. Dirty
    7,949Coins
    Afaik, it is totally fine withSimTools 2.5. In fact, it is completely agnostic to which version you have installed.
    Have you unpatched DCS from the original plugin before patching with this plugin?
    Troubleshooting:
    1. Go here: https://www.xsimulator.net/communit...cs-experimental-plug-in.239/update?update=757 and get version 0.10. Patch through SimTools' PluginUpdater.
    2. Got to "SavedGames/DCS/Scripts" and check if there is a file called "Export.lua". Just to be sure, rename that file to something else. Don't delete it, just rename it!
    3. Go to "SavedGames/DCS/Scripts/Hooks" and check if there is a file called "SimTools_DCS_Exp_Hook_v010.lua" in there.
    4. Report back here for further instructions :)
  19. janio
    state employee
    belo horizonte
    184Coins
    thanks to @noorbeast for taking care that everything goes well. I am very grateful for the coins. now just get on my f5 and go up to the sky. rsss
  20. janio
    state employee
    belo horizonte
    184Coins
    extra1, 2, 3 are not receiving telemetry data, has anyone been there? the other dofs working normally. (plugin version 0.10) I like this plugin mainly because it has onground data.
