Building my 2DOF v1.0
Discussion in 'DIY Motion Simulator Projects' started by quq404, Nov 3, 2020.
Tags:
  1. quq404
    quq404 New Member
    Russia, Yekaterinburg
    - 98Coins
    Hi
    Begin to building my 2DOF. In my view, the structure should be compact and demountable. Having looked through many options drawing it in a sketchup.
  2. quq404
    quq404 New Member
    - 98Coins
    Standart components:
    Arduino Uno x1
    Driver IBT-2 x2
    Power supply 12V 50A x1
    Gear Motors GM96303118 x2
    small components
    I really hope that the power of the motors will be enough for this project, the main thing is to balanced the weight.
  3. quq404
    quq404 New Member
    - 98Coins
    Progress today:
  4. quq404
    quq404 New Member
    - 98Coins
    Oops! The first size error. We'll have to redo it :)
  5. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    550Coins
    In my build i got motor problem so you must be carefull for the (CTC) distance ( the rod size and position) .. i tryed many position then got the best movement but now i got temperature problem so you must do one of two ..change (CTC ) distance or get more powerful motor like (Worm gear motor, Wheel
    chair motor or truck wiper motor.. Hope its help and just wait for (@noorbeast) he will advice you the best
  6. quq404
    quq404 New Member
    - 98Coins
    Thanks for the advice :)
  7. quq404
    quq404 New Member
    - 98Coins
    fixed:
  8. quq404
    quq404 New Member
    - 98Coins
  9. quq404
    quq404 New Member
    - 98Coins
  10. quq404
    quq404 New Member
    - 98Coins
  11. quq404
    quq404 New Member
    - 98Coins
  12. quq404
    quq404 New Member
    - 98Coins
  13. quq404
    quq404 New Member
    - 98Coins
    Now need to securely fix the driver's seat:
  14. quq404
    quq404 New Member
    - 98Coins
    Tuning motor gear:
  15. quq404
    quq404 New Member
    - 98Coins
    Fixed studs М6 by epoxy glue for connection with potentiometer:
  16. quq404
    quq404 New Member
    - 98Coins
    I like silence :)
  17. quq404
    quq404 New Member
    - 98Coins
    First testing:
  18. quq404
    quq404 New Member
    - 98Coins
  19. quq404
    quq404 New Member
    - 98Coins
    I wanted to use "monster motor shield", but that worked with errors. The left engine was not moving well. The problem turned out to be the "monster motor shield", it was defective. The left channel only gave out 6 volts.
  20. quq404
    quq404 New Member
    - 98Coins
    Has anyone testing this module?
    Looks promising, but little information about it.
    60A High Power MOS Dual Channel H-bridge DC Motor Driver Module:
    link
