Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Thank you Lord For always being at the foot of the canyon The truth does not do that we would do without you ... I have no idea how many people from different part of the world you will like the happy woman the grader that the program would have to call Stiofoolsyobuddy.
  2. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    Tested and it works with Serial !
    Thank you for the work hug:
  3. Scblacksunshine
    Scblacksunshine Member
    270Coins
    2DOF, 3DOF
    Thanks for the update. It's working again just like 2.4 on the latest version
  4. dedenico
    dedenico New Member Gold Contributor
    - 124Coins
    I would like some help about output axis testing on simtools Game engine
    I am a registered user of simtools pro and games simtools plugin
    My hardware:
    Mobo: asus z390p
    Processor: Intel Core I7-9700k
    Video Card: Asus gfore 2070 super
    Windows 10 version 2004
    Equipment:
    3 worm drives 100 watts
    Arduino smc3 with smc3util
    Monster motorshield, one MM per motor
    2 motors for front movements pitch and roll
    1 motor at back for traction loss
    Everything works well with smc3 util, sine wave, triangle wave and motion
    180 degree up and down with smooth motion
    However when install with simtool ver 2.4, and version 2.5 and now with version 2.5.1
    Always the same problem with output axis testing very jerky motion, from 0 to 53% no movement then suddently
    move to 54% one shot and then continue up to 100%, samething when going back no movement from 53% to 0 then
    move back to middle one shot, then on negative side movement is smooth. It depends if direction is clicked,
    then the movement is jerky on the negative side.
    I change the Serial_InterfacePlugin.dll form various version 2, 2.2, 2.3 and 2.4 but just some small changes in movements,
    but still jerky moves.
    I change also to region English Us.
    Please I will appreciate any suggestion that could use my simulator smoother
  5. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    You should put a couple of photos of axis assignments to see your settings ... and interfaces settings
  6. dedenico
    - 124Coins
    Many thanks for reply, please see attached files for your information sorry for low quality (compression): My video file are zipped
  7. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Could you show me the configuration scheme you chose for three engines. you have the arduino and 2 monster ... you need to configure the third motor .... assign a movement I do not remember what would be the loss of traction.
  8. dedenico
    - 124Coins
    I have 3 motors configured with 3 moto Monster sheild, the traction loss is equivalent to sway, have a look at my video included in previous message, traction loss is sent thru axis 3a, as seen in next pic, you will also see config of my three motors...
  9. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,509Coins
    I think there may be a bug with traction loss. I upgraded from 2.4 to 2.51 and my rig movement became erratic. Just about lost my lunch when I tried it yesterday! :(
    I initially thought it was to do with the linear/rotational mode changes but it turned out that if I increase my values for traction loss in Tuning Center by 100x, I get normal movement again. Probably a decimal point misplaced somewhere?
  10. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    You know that using the connection scheme of a single arduino with more than one monster makes everything more complicated to configure the forces that you want to give to each motor, the recommended thing would be to use an arduino for each monster and there are uses in interface settings / interface 1 interface 2 and interface 3 and you have to specify the force and filter that you want to give to each motor.
  11. dedenico
    - 124Coins
    Thanks again for reply, but I did follow instructions on this forum for the build:
    To get one Monster Moto working you have to wire the two boards described as follows:
    Remark: The wiring meets the specifications of the MM. This is important to prevent any short circuit.
    (SMC3 code can access up to 3 motors using one Arduino. If you want to connect 3 MM please wire described as follows:
    Arduino -------- Monster Moto
    2 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    3 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    9 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 2
    4 (Motor 2 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    5 (Motor 2 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    10 (Motor 2 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 3
    6 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    7 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    11 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    The outputs:
    A1 and B1 will have the SAME polarity
    A2 and B2 will have the SAME polarity, too.)
    Even if I try only one axis and remove the others on axis configuration, the mouvement is the same on output testing. Are I am the only one using one Arduino with 3motomonster?
    I just want to be sure its not a bug with simtools game engine and Windows 10 2004, before I change my hardware with 3 Arduino. I just follow instructions as per your forum and my setup is working perfectly with smc3utils. Any others suggestions
    Thanks for taking time to help
  12. dedenico
    - 124Coins
    I finally solve the problem, in region settings, english us, I had checked the (Beta: Use Unicode UTF-8 for worlwide language support), I unchecked it and everything worked as intended, hoping this will helped others with same problems...
  13. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    stay calm with the problem that simtools had with win10 2004, it is already solved with version 1.5.1.
  14. morpwr
    morpwr New Member Gold Contributor
    36Coins
    So V3 has been mentioned a couple times now. Any hints on whats coming in the new version or when its coming? Hopefully on the fly tuning?
  15. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Let it be soon and that the people of simtools surprise us with many system and aesthetic improvements. I do not want to say that what we have is bad but it would be good to make a topic for the forum members to say what tools or improvements they could add ... well let's continue with the wait.
  16. noorbeast
    152,045Coins
    +11,062 / 56 / -2
    This is the correct thread for any member to suggest enhancements.
  17. yobuddy
    51,016Coins
    Well what do we have here? :D (thx for the video @nclabs!)
  18. noorbeast
    152,045Coins
    +11,062 / 56 / -2
    Now that is an exciting teaser!
  19. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    10 points the video ..... I do not see the time that this vercion comes out. there is no release date this is exciting. God willing, I'm going to release it with my 4dof.
  20. Scblacksunshine
    270Coins
    2DOF, 3DOF
    Wonder if v3 will be able to do something similar to Xbox. Tactile feedback on the actuators. I think it will he added for the Thanos controllers but wonder if it is possible with serial USB interface
