Question The question of motors for a 2-3dof
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Edik, Oct 15, 2020.
  1. Edik
    Edik New Member
    59Coins
    2DOF, 3DOF
    Hi, everybody. I collect spare parts for the construction of the 2-3dof platform. I came across such motor reducers, there are doubts that they are very powerful for such a case.They are not very expensive, but there are only 2 pieces. So I think whether to buy for 2dof similar engine. 600w, 33A, 3600 1/min, 24v, NMRV040.
    Help with competent advice)))
      154.5 KB
      451
  2. Edik
    Edik New Member
    59Coins
    2DOF, 3DOF
    There are a couple of other gear motors, but there are motors with different parameters. Can I use different motors in the 3dof platform? Or pick up all 4 motors and build a 4dof platform?
      108.6 KB
      400
      257.1 KB
      361
    153,866Coins
    +11,152 / 57 / -2
    Do you know the final gear ratio?
    They seem like they are plenty powerful, particularly the first one.
  4. Edik
    Edik New Member
    59Coins
    2DOF, 3DOF
    Should they be considered as a purchase? The price for all 4 motors is 140usd. What is the maximum allowable speed should be at the output from the gearboxes?
  5. Edik
    Edik New Member
    59Coins
    2DOF, 3DOF
    On the first engines, the output speed is 90-100 rpm. The seller does not know, he sent me a video of the work and I counted about by eye)))
    153,866Coins
    +11,152 / 57 / -2
    90-100 rpm is plenty fast enough for good motion.
  7. Edik
    Edik New Member
    59Coins
    2DOF, 3DOF
    Can I use these motors? Or is it excess power? Do I need to look for a third one, or can I use 2 600w motors and 2 500w motors in one platform? I'm still confused by the number of amps 33, I need to find a suitable driver.
    153,866Coins
    +11,152 / 57 / -2
    Yes you would need a suitable driver, something like Sabertooth.
    They are a bit excessive for say a basic 2DOF, but it really depends on what you plan to build.
  9. Gadget999
    12,132Coins
    use wheel chair motors with a gear ratio between 25:1 and 50:1
  10. Edik
    Edik New Member
    59Coins
    2DOF, 3DOF
    When purchasing these motors, the manufacture of 2dof is not considered. If I take them only under 3 or 4dof platform. I have the ability to use a milling machine to make any aluminum parts for such a platform.
    I have the only thing that caused doubt is that the motors are of different power, 2 motors at 600 watts and 2 motors at 500 watts and they have different speeds. Another problem with the sabertooth driver. We have a problem with ebay and amazon orders. I can only buy them on Aliexpress, but there are no Chinese drivers. And Chinese drivers may not be able to withstand such a load. If you know proven drivers that can be used instead of sabertooth, please tell me.
  11. Edik
    Edik New Member
    59Coins
    2DOF, 3DOF
    If on such a platform install a 500-watt motor in the front, and put 600-watt motors in the back?
