Thanos Direct Drive with AASD 30 driver
Discussion in 'Direct Drive Wheels' started by Gadget999, Sep 28, 2020.
  1. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,444Coins
    AC motor, 6DOF
    I have to ask..
    You have installed and run the programming / testing software right?
    Wheel Check will test the encoder pulses .
  2. Gadget999
    12,035Coins
    ok
    the wheel is working
    but
    I have had to set the mmos software to NOT use the index
    sometimes the aasd powers up with an error 9 message and sometimes it is ok
    there is a index pulse from the encoder - but the aasd is not transmitting it on
    not sure what is going on - i am tempted to wire the index pin on the TDD directly to the encoder without using the AASD
    does anyone have suggestions for an encoder / repair ?
    this video show what happens when the index option is turned on
  3. T R Para
    Cincinnati, Oh
    2,444Coins
    AC motor, 6DOF
    At this point until you use a shielded motor cable and a proper EMI filter on the AC mains your going to continue to have problems.
    Good luck my friend.
  4. Thanos
    Electronics Engineer
    2,862Coins
    Under the Core407v there is a solder jumper that has to be changed from Voltage In to Voltage output 5v... can you see if that is correct like in the photo?
  5. Gadget999
    12,035Coins
    Pic attached
    If i put 3.3v to the index pin will that force the board to accept motion ?
    Do i need to measure any voltages ?
  6. Gadget999
    12,035Coins
    I tried an emi filter on the mains today
    No change
    At one stage i coiled up the lead from encoder to the aasd driver and manged to get the index to work but it was very intermittent.
    Turning the aasd on sometimes I get a error9 and sometimes not.
    Last week before i changed the aasd settings it was fine.
    Is there a way to adjust the gain / voltage of the encoder ?
  7. T R Para
    Cincinnati, Oh
    2,444Coins
    AC motor, 6DOF
    Have you tried the "EMF detector" app for your phone>
  8. sedesa tatasa
    sedesa tatasa Member
    509Coins
    z also has an open collector output.
    It may work.
    What is the reason for not using the mige driver?
  9. Gadget999
    12,035Coins
    Will try it tomorrow (y)
  10. Gadget999
    12,035Coins
    The TDD thanos board only works with direction pin and pwm
    The mige driver needs a positive and negative pwm for cw/ccw - i did get it working but the support was bad and I didn't want to be the only one with no community support
  11. T R Para
    Cincinnati, Oh
    2,444Coins
    AC motor, 6DOF
    I see in your video the analog axis is set differently. I have no idea if it effects anything or not
      155.5 KB
      483
  12. Gadget999
    12,035Coins
    Good idea
    However why is my aasd driver powering up with a fault :(
    I found spinning the wheel on start up gets it to power on correctly
  13. T R Para
    Cincinnati, Oh
    2,444Coins
    AC motor, 6DOF
    If you disconnect the motor wires and the DB25 connector so that only the Cn3 encoder is plugged into the AASD-30 and power up is it coming up AL-09?
    If so It might be worth doing a Fn04 reset again and check for AL-09 without setting any of the Pn-xxx addresses..
  14. Gadget999
    12,035Coins
    I reset the aasd drive
    I powered it on with and without the motor wires attached
    I checked for emi - it was very minimal
    I tried extra earths
    Again it appears to be intermittent, sometimes it powers up with error9 and sometimes it is fine
    I think I am going to wire up the encoder from my other servo motor and see if the problem persists, it has a much larger resolution so it could be a bonus !
  15. T R Para
    Cincinnati, Oh
    2,444Coins
    AC motor, 6DOF
    Well I would say you gave it a good try. I am not sure what components are used in the encoder that are easily tested.
    Once again DN023 should show problems with the encoder (I would think).
    On the 6dof project I am working on I am using 6 AASD's drives and I have redone all the cabling. My motor cable is about 300mm long and I have made the encoder cable 300mm also. AL-09 will come up immediately if I miswired the DB15 connector.. I also had a AL-09 alarm even with a properly wired encoder cable and was fixed by a Fn04 reset . I had a 3rd motor setup that would just slowly rotate back and forth (for hours if I let it) and it too was some kind of scrambling in the eeprom. Fno4 reset fixed that too.
    I don't see that many intermittent problems with SMD components and machine soldering..
    However,, Anywhere a Human Assembler with a soldering Iron is still prone to error..
    I hate to continue with this saga (lol)..
    But that has not stopped my yet !
    If you power up the AASD and with no AL-09 If you shake the cabling/connectors/AASD or motor will that ever cause a AL-09?
    It is also pretty safe to remove the rear encoder cover to inspect for any pinched or damaged wires.
    I also believe if one of the 3 main legs of the motor leads has chaffed insulation and grounds to the metal housing it can cause a AL-09.
    Again sorry your having these problems.
    This should be just a fun hobby.. Not a frustrating one..:cheers
  16. Gadget999
    12,035Coins
    @T R Para yes I agree ! this is a bit of fun and is should not be too stressful !
    however on the plus side I have learnt loads about servo motors - I would have learnt nothing if it worked first time !
    My opinion is it is probably best to control them using the data port and not use volts and wires that can be affected by EMI
    I suspect the problem has been there from the start and is caused by the mige cabling and aasd driver not liking each other
  17. HappyMedian
    HappyMedian New Member
    29Coins
    Hi all,
    I also made a build with a 130ST-15015 and the AASD driver and Thanos board, works great, but I get those really high pitch noises from the servo driver. Judging from the videos in this thread, that seems to be normal or is this fixable ?
  18. Gadget999
    12,035Coins
    The noises come from the frequency the driver works at
    The only option is to turn the sound up
  19. HappyMedian
    29Coins
    Okay thanks. I just setup my motor yesterday so I did a little bit of driving today and I have to say that I get a fair amount off motor noise. Is there a way to bypass the DAC that I can compare with and without DAC, just to see how much the DAC affects the motor noise?
  20. Gadget999
    12,035Coins
    Yesterday the ASAD driver was acting a bit strange, I open it and reseated the top circuit board
    the encoder error Alarm 9 has gone :)
    I suspect it got shaken about whilst being delivered
    Does anyone use the MMOS 14 generation wheel with R Factor 2 ?
    where do i get the correct driver from
