Buckle up for Project Cars 3 - Summer 2020
Discussion in 'Project Cars' started by noorbeast, Jun 4, 2020.
  1. Newgun
    Newgun Member Gold Contributor
    77Coins
    AC motor, 4DOF
    Yup, I can confirm as well that renaming the .exe file did not work for me. In my case , when I rename pCARS3 to pCARS2, Steam would automatically update and re-create the pCARS3 .exe file while retaining the renamed file pCARS2. However, clicking on the pCARS2 (renamed .exe) opens the game but does not trigger the plugin in SimTools. Here's a screenshot of the two .exe files coexisting in the game folder.
    Gonna try the method suggested above by Sarge. Thanks again Sarge!
  2. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    @yobuddy Can you make the pcars3 plugin so whe don't have to rename files? Thanks.
  3. yobuddy
    51,008Coins
    Sure, I'll take a look tomorrow guys.
    • Like Like x 5
  4. RobertH
    RobertH Member Gold Contributor
    The Netherlands
    1Coins
    2DOF, SCN5
    Any news?
    152,027Coins
    +11,062 / 56 / -2
  6. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    Has anyone tested project cars 3 in VR?
  7. yobuddy
    51,008Coins
    Which Pcars2 plugin is confirmed working for Pcars3?
    I have a couple of them is all...
  8. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    Hi yobuddy, I've been using the UDP version with manual start. It works but has a few issues such as jumping in the menus and movement during replays... I think Project Cars 2 did this also if I remember right? Gameplay is perfectly fine.
    I couldn't test the normal plugin, as Steam wouldn't allow a name change on the exe.
  9. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    Yes but it is not as good as in PC2, looks like it needs some more tweaking.
  10. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    is it possible to use project car 2 pluging for the pc3 ?
  11. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    Yes the instructions are in this thread
  12. Gouffy56
    Gouffy56 New Member
    298Coins
    4DOF
    I have ProjectCars and ProjectCars2. In find these software's have to many parameters to adjust before driving. For example, Assetto Corsa competitione is much more friendly user, you can drive the game straightforward, as downloaded what about PCars3, is this game as difficult to set as the previous PCars? What incentive to buy PCars3 when you already have the 1 and 2 versions?
    Regards
  13. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    Project cars 3 is more of the same, nothing new. The graphics and FFB are worse than PC1 & PC2.
  14. Gouffy56
    Gouffy56 New Member
    298Coins
    4DOF
    Thank you, so minimum incentive to go to PCars3.
  15. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    I would spend my money on Forza Motorsport 7 ;)
  16. Gouffy56
    Gouffy56 New Member
    298Coins
    4DOF
    I've heard about Forza but never had the opportunity having a look to it. Despite I have 6 driving/racing games (Assetto Corsa, Assetto Corsa Competizione, PCars, PCars2, Dirt Rally, Dirt Rally 2,), I'm usually always using the two same ones (Assetto Corsa Competizione and PCars2), thus I'm not convinced the more games, the more attractive my rig will be. Anyway, thank you for the suggestion, I've some friends using Forza (not on PC), I understand they are very happy about this game, so I may have a look to it.
    Regards
  17. PEB
    PEB New Member Gold Contributor
    - 78Coins
    4DOF
    It's amazing Forza 7 well worth the time to setup check it out hundreds of tracks and very good on the motion simulator. Assetto so far has been the gold standard for me but Forza has pulled right up to it. https://www.facebook.com/watch/?v=1041493982966270
    https://www.facebook.com/watch/?v=373322323713133
    It's also currently on sale for 59.00 dollars for Deluxe.
    Heads up one day left on the sale.
    https://www.xbox.com/en-US/games/forza-7
  18. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    i think i try project car 3 the last week
  19. luu trung
    luu trung Member
    172Coins
    why does the engine move slightly while waiting to load game project car 3?
    152,027Coins
    +11,062 / 56 / -2
    Likely because there is some game telemetry and/or difference between the rest position of the rig and the initial game telemetry position.
