$450 Mige Direct Drive Wheel using MMOS and AASD
Discussion in 'DIY peripherals' started by Peacemaker105, May 6, 2020.
  1. bdam
    bdam New Member
    120Coins
    Related to @JonBakhol's question: is there a page/wiki somewhere that explains the difference between the MMOS/Simucube solutions? It seems to me to be the motor driver (AASD vs Simucube/IONI) with the Simucube solution seemingly getting all worked up about having the best encoders.
    My 90ST-M04025/AASD15 just cleared customs so I've already made my choice but am interested none-the-less.
  2. Thanos
    Electronics Engineer
    2,854Coins
    The MMOS is old firmware from 2014. It supports encoders up to 65535 Counts per revolution (The AASD servo has 10000 cpr).
    Simucube supports a bit better control of the servo as they use new firmware that talks digitally directly to the Ioni driver electronics, instead of using pulses or DAC on the MMOS firmware. Also because of newer firmware the Simucube supports higher resolution encoders as well.
    Other differences is more combined effects in the games or more settings (which I'm not sure about, I haven't tried one yet).
    Thanos
  3. bdam
    bdam New Member
    120Coins
    Thanks for the break-down @Thanos, much appreciated.
    Interestingly enough, from the original MMOS thread it looks like someone has taken up the torch to create an open-source a STM32-based replacement: https://github.com/hoantv
  4. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    443Coins
    @all. The pedals and shifter from the G27 can be connected to the STM32 board. What about the CSL Elite pedals from Fanatec? I think it's the same wiring?
    Ground / +5V and the pot measurement?
    I do have the small black RJ12 connection box from Fanatec. So I think about soldering the RJ12 cable (which goes to the wheelbase) to the DB9 connector.
    Please share me your thoughts.
    TIA
    Bakhol
  5. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    Just a FYI This board seems to work fine with this project and its cheap and available from amazon. It does not use a stm programmer but instead uses a dfu file which is sent via the usb jack on the board The programming software is available from ST.com
    www.st.com/content/ccc/resource/technical/software/demo_and_example/93/55/e0/89/d1/e3/40/d5/stsw-stm32080.zip/files/stsw-stm32080.zip/jcr:content/translations/en.stsw-stm32080.zip
    Google drive link https://drive.google.com/file/d/1lcHjFLZAo4nqiLp407oG2OF-sguk0sID/view?usp=sharing
    www.amazon.com/gp/product/B081BCXST2/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    ADDED> The converted firmware Hex to DFU file..
    I forgot to mention... you must short the BTO pin (next to the usb socket) to 3.3v to get the board into the DFU mode
    ADDED> If you are in the US and are looking to buy the 130ST motor and matching servo driver complete with cables here is a link for them on Amazon. Today there were only 2 left. I do not think you can find it cheaper considering shipping from China is over $150.. This motor ships free from California via UPS. It is a monster of a motor..
    I dislike posting items that will go out of stock soon so I will edit this post when this item is no longer available..
    www.amazon.com/gp/product/B07W4K64S6/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
  6. JonBakhol
    443Coins
    @T R Para
    Hmm..I think Nema is a stepper/hybride
    Servo is analog. Steppers are always.....stepish?
    Shoot me if I'm wrong.
    Bakhol
  7. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    My understanding is that NEMA is a specification dealing with the size of the mounting holes and such.. It is confusing.. What matters here are actually model numbers and exact specifications of the motor. The motor described in this thread is not a stepper.. it is a 3 phase brushless motor with a 2500 position encoder per revolution. This allows a precise positioning and accurate return to center.
    The AASD-30 servo driver allows additional control of the motor such as speed,torque,motor position and actually much more. The software written for this project is specific to this type of motor system. I am no engineer.. More of what is called a "solder jockey".. I can take what the smart guys design and with a drill press. hacksaw and soldering iron I get to play with their amazing ideas.... LoL.
  8. JonBakhol
    443Coins
    He Guys, Quit busy with preparing all the stuff.
    Anybody an small drawing how to "drop" the DAC between the stm32f4 and servo signal?
    TIA
    Bakhol
  9. vicborder
    vicborder Vicborder
    - 529Coins
    [QUOTE = "JonBakhol, publicació: 204028, membre: 29364"] Ell, nois, s'ha ocupat de preparar totes les coses.
    Algú té un petit dibuix com "deixar caure" el DAC entre el stm32f4 i el senyal servo?
    VIA
    Bakhol [/ QUOTE]
  10. JonBakhol
    443Coins
    @vicborder . I think I mean something else:
    This piece needs to go somewhere?
    TIA
  11. vicborder
    vicborder Vicborder
    - 529Coins
    i don't know what it is, if you want to put an DAC to buffer the noise of the engine is the scheme you passed
  12. JonBakhol
    443Coins
    I think you are right about the noise. But the conversion from PWM to a smooth Analog Voltage isn't needed?
    TIA
    Bakhol
  13. vicborder
    vicborder Vicborder
    - 529Coins
    you can raise PN189 to have more PWM
  14. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    @JonBakhol The input pin (pwm) on that chip I believe is pin 6 the analog output voltage is pin 2. There are actually 4 separate converters on that chip. PE9 coming from the STM board goes to the input pin6 and the output of the chip goes to pin25 of the db25 connector... Please understand that chip is extremely small and cannot just be soldered to. It needs to be mounted on what is called a breakout board before you can solder any wires to it... You would need surface mount (SMT) equipment to do the job and a microscope would help too.
    www.digikey.com/htmldatasheets/production/1615665/0/0/1/ltc2645.html
  15. JonBakhol
    443Coins
    @T R Para
    Thanks that's what I wanted to know. I'll try by hand. (Soldered alot of smallest SMD components by hand)
    Will post the outcome when all is arrived and running.
    Bakhol
  16. JonBakhol
    443Coins
    When I enable "Use Encoder Index" my pedals stop working. When disable it. My pedals come back to life. Anybody an idea?
    TIA
    Bakhol
  17. sedesa tatasa
    sedesa tatasa Member
    509Coins
    JonBakhol
    When using "Use Encoder Index",
    mmos will not start until the z signal is input.
    Is an encoder signal connected?
  18. vicborder
    vicborder Vicborder
    - 529Coins
    look at the connections that are correct
  19. JonBakhol
    443Coins
    @sedesa tatasa . Thanks for the reply. I already thought something like this was the problem. I'm waiting for the motor. So I thought to get everything prepared in front. The encoder isn't attached as you can see. I'll see when the motor arrives.
  20. vicborder
    vicborder Vicborder
    - 529Coins
    without Encoder, it's not gonna work
