Tutorial Some questions?
Discussion in 'New users start here - FAQ' started by pfm21, Jun 15, 2020.
  1. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    I followed the video but I can't find the plugin to paste in the LFS folder that I have to take from simtools? thanks
  2. pfm21
    374Coins
    Is it possible to have the arduino-motomonster connection scheme?
  3. pfm21
    374Coins
    I made all the connections, loaded smc3 but the engines do not move
  4. lindo123
    lindo123 Gamingfeeling
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    Hello, you don't need the plugin to paste in the folder. You go on Simtools game engine and click patch. Then, you select the LFS folder. I also had this problem my self.
  5. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    Have you changed the configuration folder to the com port of the arduino. Or the right com port.
  6. pfm21
    374Coins
    Yes i do
  7. pfm21
    374Coins
    Do you have a picture of arduino- motormonster?
  8. pfm21
    374Coins
    Connection diagram
  9. pfm21
    374Coins
    I use this
  10. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
  11. pfm21
    374Coins
    Ok.sorry. I connected everything. followed all the simtools settings. the game connects and simtools reads the telemetry. as soon as I connect the motors they turn but the game doesn't make them move. what can I do
  12. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    Have you connected the potentiometers to the motor so the motors know what position to spin? ( where they are) They need to be on the motor so the pot moves with the motor.
  13. pfm21
    374Coins
    Yes connected
  14. pfm21
    374Coins
    This a picture
  15. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    Did you configure the position of the potentiometer when you put it on there E.G show the middle point of the motor on smc3.
  16. pfm21
    374Coins
    can you help me?
  17. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    I will post more tommorow about it. Basically, you stop the motor from spinning then put the potentiometer to the middle position then glue/ attach the pot (in the middle position) then re apply power go into smc3 along the side are controls E.G motion/manual/square wave ext click on manual and use the mouse to move the motor around along the right side. To turn the motor off take away the power from the Power supply.
  18. pfm21
    374Coins
    ok. thank you very much friend
  19. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    Hello again, another thing to consider is that in the tutorial video he's using a different motor controller This meant he had to edit the code. With the moto-monster, if you've wired it right, it should just work with the deafult sketch and you don't have to change any code.
  20. pfm21
    374Coins
    can you take a picture of the parameters to put on simtools? I would like to do it for F1 2019, do you have the plugin to try? thanks
