KartKraft Plugin 1.0.0.1
SimTools game plugin for KartKraft
  1. kwak
    kwak Member
    - 324Coins
    Excellent it works with your method, it's been several days that I try and no movements now everything is perfect thank you very much;)
  2. Daguru
    Kitchen installer
    Wales uk
    469Coins
    Motion platform
    I since tracked the program that kept using that port and uninstalled it and no problems since
  3. kwak
    kwak Member
    - 324Coins
    Ok very Thanks
  4. Kaneda
    Kaneda New Member
    84Coins
    Hi
    I have problems with kartkraft, I use 2 systems :
    Prosimu T1000 3DOF with simtool and Geko Acuator with Gseat manager software
    The problems both use port 5000.... (first time have that )
    I see in setting kartkraft its possible to change port
    If i choose for exemple Port 5005 how i modify game.ini for have port 5000 and port 5005 use in same times ???
  5. Daguru
    Kitchen installer
    Wales uk
    469Coins
    Motion platform
    what software do you want to run on port 5005
  6. Kaneda
    Kaneda New Member
    84Coins
    Hi !
    if i can have 5000 for geko and 5005 for simtool ?
  7. Daguru
    Kitchen installer
    Wales uk
    469Coins
    Motion platform
    can you change the port in geko? @Kaneda
  8. Kaneda
    Kaneda New Member
    84Coins
    I have the impression that yes !!
  9. Daguru
    Kitchen installer
    Wales uk
    469Coins
    Motion platform
    If you can paste this in the game.ini
    [/Script/project_k.UDPManager]
    bConfigOverride=True
    OutputEndpoints=127.0.0.1:5000
    OutputEndpoints=127.0.0.1:5005
    bEnableOutputStandard=True
  10. Daguru
    Kitchen installer
    Wales uk
    469Coins
    Motion platform
    I believe simtools is locked at 5000 for this plugin so change geko to 5005 and enter above in game.ini and it should work good luck.
  11. Acetre
    Acetre New Member
    Karting Coach
    162Coins
    Hi all,
    Maybe my question is strange for you, but I want a confirmation.
    I'm very interested in Kartkraft, i want to get the telemetry of the laps in a session, to study brake, accelerator, position, RPM, speed...
    So, my question is : If i use Simtools with the kartkraft plugin, can I get all theses informations ?
    The perfect would be a presentation like Motec
    152,694Coins
    +11,090 / 56 / -2
    On the plugin Download page the plugin Dev lists the following as currently exposed:
    Motion data:
    This plugin provides pitch, roll, yaw and surge, sway, heave acceleration and traction loss.
    DashApp Data:
    Speed, RPM, Gear, Position, Lap, Lap Time, Total Laps
  13. AlbertoMoralo15
    AlbertoMoralo15 New Member Gold Contributor
    - 21Coins
    I´ve recently bought KartKraft and install the plugin, but nothing works. I think it is due to the process name. Game Manager doesn´t detect project_k
    Any help?
  14. JohnCrichtonFR
    JohnCrichtonFR JohnCrichtonFR 5 DOF Gold Contributor
    Maintenance Technician
    22Coins
    4DOF, 6DOF
    Hi Alberto, have you activated on the game the telemetry and verify the UDP port (default is 5000) ? Or you have another problem... Have you patched the game plugin ?
  15. AlbertoMoralo15
    - 21Coins
    Yes I have installed amd verify only UDP is on
    My port is 5000
    I don´t know why my Game Manager doesn´t detect the game is on
    i mean it is in green but not on blue
  16. JohnCrichtonFR
    22Coins
    4DOF, 6DOF
    I d'ont understand what you will say, can you send some screen pictures please, maybe it can help...
  17. AlbertoMoralo15
    - 21Coins
    Here you are
  18. AlbertoMoralo15
    - 21Coins
    There has been an update recently, that could be the problem. They have introduced a new series
  19. JohnCrichtonFR
    22Coins
    4DOF, 6DOF
    OK, so, I see "patched" in "Red" on "game manager", this means that your plugin is not patched. re-patch the plugin first and then it should work ... you will see "patched" on "Green" when it's OK.
  20. AlbertoMoralo15
    - 21Coins
    Now it works perfectly, thank you a lot!!!!
