Showroom Compact 2dof Seat
Discussion in 'DIY Motion Simulator Projects' started by Santrovitsch, Apr 30, 2020.
  1. Santrovitsch
    Santrovitsch New Member
    - 10Coins
    Hi evebody.
    I start my 2dof project, with cheap components. I will post here my project.
    152,045Coins
    +11,062 / 56 / -2
  3. Santrovitsch
    - 10Coins
    Yes, I know about the torque. I will use an motor with 35Nm and 70rpm, i believe 50:1. I try to use de sincalc, but not accept small size of measurement.
    You know how much angle of pitch and roll is good value? 10 deg?
  4. Santrovitsch
    - 10Coins
    I try with the forum an license for my Rig, but says that I an not qualify. How to get qualify?
    Sorry my terrible english!
    152,045Coins
    +11,062 / 56 / -2
    To qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the rig testing phase.)
    • Have been a member of the community for at least 30 days.
  6. Santrovitsch
    - 10Coins
    New's!
    Today I receive some part's and begin to work!
    H Monster assemble with some mod's. I will integrate to arduino and H Monster an bluetooth module to make a direct commnication to PC wireless without a second Pc. The speed of usb-serial of arduino Uno, is 115k and bluetooth is 115k too, and I believe that work without no lag. Feedback of position will be hall sensors
    20200501_213924.jpg motor support's
    I find this tutorial:
    https://create.arduino.cc/projecthub/millerman4487/view-serial-monitor-over-bluetooth-fbb0e5
  7. Santrovitsch
    - 10Coins
    More part's!
    Motor:
  8. Santrovitsch
    - 10Coins
    More part's of the project:
    image-1.png Seat
    Join
  9. Santrovitsch
    - 10Coins
    Final design:
  10. Santrovitsch
    - 10Coins
    Position feedback 3D Printed:
  11. Santrovitsch
    - 10Coins
    Arm of the motors:
  12. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    I noticed that he is Brazilian too. I am using similar engines in my project. I bought the 70rpm 35nm but found it weak (for my purpose). Then I bought the 30rpm 50nm and it worked!
    Are you interested in turning your project into a commercial product?
  13. Santrovitsch
    - 10Coins
    I will try with the 82rpm motor, if not work well, I change to the motors that you inform.
    In this moment I will assemble the project to my use, but I can think to change to commercial. I have good ideas to do the comunication for the pc wireless, triple screen's with low cost projector's and other things.
  14. Renaudeau
    Renaudeau Member
    116Coins
    Hi, thanks for sharing. I will follow your project with interest
    Do you have the characteristics and the reference of the electrical elements? (engine, engine control card)
  15. p00ky
    p00ky Active Member
    Self Employed Laser Cutter
    Wales
    392Coins
    That's a nice compact design. I'd be interested to see what SimCalc said about your no.s. I'm in the design phase right now, waiting on parts to arrive & I'm a little unclear on the sort of no.s I need to see.
  16. Santrovitsch
    - 10Coins
    Yes!
    Arduino Uno R3
    Power Supply 12v 50A 600W
    Motor:
    H Monster
  17. Santrovitsch
    - 10Coins
    More progress!
  18. p00ky
    p00ky Active Member
    Wales
    392Coins
    Wow that is sleek. I hope the Alu extrusion can cope & that no one needs to get into the closet :D Makes me wonder if I've gone a little over bvoard for my first build.
  19. Santrovitsch
    - 10Coins
    :grin! The final position of the rig I don't know were, but is not in front to the closet!
    I will do all the rig with alu, to get a nice view. I order de part's today.
    Will be moreless like this:
  20. p00ky
    p00ky Active Member
    Wales
    392Coins
    Looking good :) The thing I just made weighs a ton, I should have thought of Aluminium Extrusion. It makes for a nice neat and probably quite quick build. I shall be watching with interest.
