AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. JAD
    JAD Active Member
    Australia
    1,446Coins
    I'm going for ballscrew with direct coupling so no need for gearboxes.
    But point taken.
    Cheers
  2. Thanos
    Electronics Engineer
    2,868Coins
    How about this one?
    https://www.aliexpress.com/item/32844239563.html
  3. JAD
    JAD Active Member
    Australia
    1,446Coins
    Thanks for that! The thrill of the hunt!
    I just found that one too as you posted it. Its currently in my shopping cart.
    They are doing something weird with shipping rates and its only economical if buying one at a time.
    I was about to post it but thought I might be pushing my welcome by spamming your thread with shopping finds.
    I cant help myself to keep going back for another look.
    But thats it, no more looking, thats as good as its going to get, Im pulling the trigger 6 times.
    Total x6 price is down to AUD$1952 inc delivery + tax
  4. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    @JAD send this guy a message if you think the shipping is overpriced, he can make you a different offer. And also he can probably make you a smaller invoice for you to pay lower VAT and customs taxes
  5. Thanos
    2,868Coins
    SRG Barry's latest review features a bit of the AMC-AASD15A controller... if you didn't seen it yet, here it is:
  6. unique83
    unique83 New Member
    65Coins
    Hi Diablo2112,
    What product did you use to solve the ground loop hum? I really want to get rid of it and don't know what product to search for and buy.
    Regards, Dan
  7. Optimus_Phime
    Optimus_Phime New Member Gold Contributor
    Director Of Technology
    Miami
    182Coins
    @Thanos sounds like just the controller I need for my new project. Do you have any idea on the time line before they may be in-stock for purchase?
  8. Thanos
    2,868Coins
    I'll have more in stock soon, waiting delivery of some parts anytime now.
    Thanos
  9. Optimus_Phime
    Miami
    182Coins
    @Thanos,
    That’s great news. Thank you for the passion you have for these projects. I have been following this projects Since last year and wish I had found my unit sooner. I look forward to purchasing as soon as stock becomes available. Keep up the great work.
  10. Thanos
    2,868Coins
    Here's part 2 of Barry Sim Racing Garage review of PT-ACTUATOR 5DOF platform:
  11. Petertje
    Petertje “Engineering changes the world.” —Isaac Asimov
    Mechanical engineer / battery specialist
    The Netherlands
    447Coins
    Have the @Thanos controller here. Reluctant to post as I feel quite stupid: cant get the motor to calibrate and move at all with the controller. What I did:
    • Read the manual back and forth multiple times
    • installed the latest firmware v2.09 according to video
    • Put all the settings according to the manual 2.3
    • Jumper is in the right position (up)
    • dipswitches also ok
    • (next to the usb is a power connector. No mentioning of this in the manual, nothing connected in pictures/video's so I guess not needed)
    • no emergency stop or something connected
    • Settings into the servodrive according to manual: its the EXACT same type as recommended from the exact supplier.
    • Motor turns when using "jog" so the drive&motor seem ok
    • When turning the motor by hand it shows values on drive display (speed? Pulses?)
    • The thanos controller is recognized by mover software, and thanos controller shows "motors online receiving data"
    But when switching them on there is no homing, and no reaction to up-down-left-right buttons.
    What I did to try to get it to work:
    • Switched both off- on again, tried different switch on sequences.
    • pressed reset button on thanos
    • tried all other servo ports
    • tried other 25 pin data cable
    • Reset both to factory settings and tried without setting anything
    • Input servodrive settings again according to manual
    • input thanos settings again according to manual
    In all cases: zip nada rien. Pointers really appreciated, maybe I'm missing something obvious. I hope so.....
  12. Thanos
    2,868Coins
    Just a shot, did you set all parameters, including the extra ones in red color?
    Thanos
  13. Petertje
    The Netherlands
    447Coins
    Hey Thanos, thanks for your reply. It was the d-sub25 data cable.... Really weird pin assignment, not 1-1 and not modem. Made a test cable to check and that works fine! So now hunting for the right data cable. Local computershop has never heard of it :)
  14. Thanos
    2,868Coins
    One like this:
    10 ft DB25 Male to Male Serial Cable 25C Straight by Otimo
    • Useful Useful x 2
  15. BURGUIERE MATTHIEU
    BURGUIERE MATTHIEU New Member
    270Coins
    3DOF, SCN6
    Hello Thanos!
    The question can already be asked, I use a translator, excuse if it is not the best translation. With the Thanos card Which motors with maximum power / force in 220 volts could be used on the same principle as those used for SXF? and, is it possible to use them in infinite rotation?
    Thanks for the answers.
  16. Thanos
    2,868Coins
    You can use planetary gearbox for 6dof platforms as well... check my Discord appropriate sections...
    Thanos
  17. Gadget999
    12,053Coins
    Hi Thanos - what motors and gearboxes are these ?
    @Thanos
  18. BURGUIERE MATTHIEU
    270Coins
    3DOF, SCN6
    I do not understand the answer to my questions, I will try to put it differently:
    The questions are for @Thanos card.
    For example, can we rotate the axis of a motor like those used by the SFX project infinitely with the @Thanos card?
    That is to say, is it possible to make any axis rotate infinitely without a stop if desired?
    Then, what are the biggest engines that the @Thanos card could handle of the same type as those used for the sfx pojet?
  19. Thanos
    2,868Coins
    These are flange 80 AASD-15A servos I think (80st, 750W). And using 100:1 planetary gearboxes.
  20. Thanos
    2,868Coins
    Right now the control method is absolute positioning, with finite range. I could add a continuous rotation mode, where the motor uses the calibration switch only to indicate start angle of the 360 rotation during power up, and continously rotate to each direction, but the command from simtools must be a speed command not position anymore...
