Possable Alternitive to TrippleHead2Go <$$>
Discussion in 'SimTools compatible interfaces' started by Brightonuk, Oct 4, 2009.
  1. Brightonuk
    Brightonuk Member
    Business Owner
    Plantation, FL
    492Coins
  2. XRiccardo
    XRiccardo New Member
    1Coins
    sorry..... but wich Monoprice product can split and expand 1 vga source to 3 vga monitor?
    Thanks!
  3. Brightonuk
    Brightonuk Member
    Business Owner
    Plantation, FL
    492Coins
  4. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Sorry to be the bearer of bad news, but none of these products will work. The idea is to take 1 video source and place PORTIONS of it on multiple screens therefore creating one large screen. All of these products are designed to take a video input and place the ENTIRE image on multiple screens therefore creating multiple screens with the exact same picture.
  5. wannabeaflyer
    wannabeaflyer Active Member
    UK - London area
    973Coins
    dont quote me on this guys and i may have gotten the name wrong but i belive ATI have a new product out calle EYEFINITY which looks like it will give matrox a run for there money and more choice for joe public :) 8)
  6. XRiccardo
    1Coins
    EYEFINITY .... but .....
    1) EyeFinity can't do mix resolutions. All 3 monitor or 6 monitor to be same size
    2) EyeFinity hasn't cylindrical correction.
    3) EyeFinity can't force resolution
    4) EyeFinity can't force FOV
    EyeFinity can do more than 3 displays and it's very simply to config it
    alternative to th2go is mview technology http://www.mviewtech.com/
    ....... or with software
  7. mviewtech
    mviewtech New Member
    0Coins
    Hello all,
    our company release our MV103-HDVE PRO ,user can buy at
    http://www.dhgate.com/p_ff808081239df6c ... 12e04.html
    input interface : one duallink DVI inerface .maxium pixel clock 330Mhz
    output interface: trhee DVI-I(can DVI-D ang VGA simulaneously),maxium pixel clock 165Mhz
    accessories:eek:ne duallink DVI cable,one 5V/2A power supply(100-240V) AC ,one RS-232 cable
    dimension:165mmx130mmx28mm
    warranty:2 year limited warranty
    product feauture.
    1.support 5040x1050 60HZ @ WINXP,VISTA and Windows7,user can connect any 22 LCD (VGA or DVI interface).
    2.user can enable DX10 in Vista and Windows7
    3.No HDCP
    4.No bezel management.
    5.support ATI and NVIDIA card with DVI output.
    6.user can configure display format with DDC or RS232.
    Mviewtech.
  8. FAG
    FAG New Member
    Perm/Russia
    413Coins
    TrippleHead2Go too can't mix different resolution and aspect ratio
    MV103-HDVE PRO can mix different resolution and aspect ratio, compensate for monitor bezel gaps ?
  9. XRiccardo
    1Coins
    correct! :thbup:
  10. mviewtech
    0Coins
    you are right!
  11. mviewtech
    0Coins
    MV103-HDVE PRO cann't mix different resolution and aspect ratio! for example 5040x1050 60Hz each monitor should be 1680x1050 60hz
  12. FAG
    FAG New Member
    Perm/Russia
    413Coins
    Yes, i have already read the specification, and the bezel gaps too is not supported. But the price very beautiful, plus 5040x1050x60hz against 57hz at TrippleHead2Go 8)
  13. mviewtech
    0Coins
    we have tested 5760x1080 50HZ and 4800x1200 55HZ that are OK for WINXP system.
    If you interesting these format,you can order it at DHGATE,and send the internal message at DHGATE and note 4800x1200 55HZ or 5760x1080 50HZ(user can only select one format for you product).we will add this format for you.
    http://www.dhgate.com/wholesale/product ... a7c67.html
  14. bvillersjr
    Ohio, USA
    438Coins
    Is 3 X 1920 x 1080 @ 60Hz (5760 x 1080 @ 60Hz) possible?
  15. mviewtech
    0Coins
    No,because 5760x1080x60= 373.3Mhz over the DVI bandwidth(330Mhz).
  16. CXCSimulations
    CXCSimulations Member
    - 9Coins
    How about an HDMI or Display Port version?
    We would use Eyefinity, but our simulators use WinXP only.
  17. mviewtech
    0Coins
    HDMI(165Mhz) or Displayport (360Mhz) can't run at 5760x1080 60HZ.
    but Eyefinity now only support Vista or Win7.
    Best Regards!
    Mviewtech
  18. pro68
    pro68 New Member
    0Coins
  19. CXCSimulations
    - 9Coins
    Can you point to a section where it mentions that it does EyeFinity on XP? The page you have referenced is a generic driver DL page.
  20. mviewtech
    0Coins
    I set up 5040x2100 60hz with 2 MV103-HDVE PRO in XP system.
    I use Nvidia tools with span mode (vertical span).user can play video or game.
    video card GTS250 with two dual link DVI.
    six monitor are Samsung 2243.
    detailed picture as following link.
    http://mviewtech.spaces.live.com/default.aspx
    Best Regards!
    Mviewtech
