What hardware is this
Discussion in 'New users start here - FAQ' started by Les, Oct 31, 2009.
  1. Les
    Les New Member
    Scotland
    0Coins
    I have been reading through the posts for a while now and was about to start building until I saw this http://www.youtube.com/watch?v=Q9d4zRs8 ... re=related I would be more interested in building something compatible with the xbox 360 as I already have a setup for use with Forza 3. Does anyone know what motion platform this is, and how its controlled?
  2. Les
    Les New Member
    Scotland
    0Coins
    Just found that it could have been made by D-Box and that Simcarft may be selling a compatible version soon, I read that it's PC based. Is this something that is or could become compatible with X-SIM. I was thinking about making something similar to the wiper motor simulators seen on here.
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Everything is compatible with X-Sim if your willing to do a little work. That's the beauty of X-Sim!
    On another note, this simulator, while a beautiful demo unit, isn't very practical, and I suspect that any production versions will be quite different. Take for example the display stand. They have a cutout for the light on the display. Not every display has a light in that location. Furthermore, it would cover the power button and the IR button on most displays, leaving no way to turn the displays on and off. ;)
    Without going into too much detail, this simulator also lacks focus on the concept of proprioception, the key to any real driver training via simulation. I will say that it is rather pretty though, and the graphics quality of the Forza / X-Box combo is top rate. I am working now to create an X-Box compatible version of the Sender for X-Sim although this is a few months off.
  4. CXCSimulations
    CXCSimulations Member
    - 9Coins
    That motion system is a ForceDynamics system custom built for that show. It ran off of a development Xbox 360 that was set to output C++ to the motion system.
  5. Les
    Les New Member
    Scotland
    0Coins
    When you say you are working on an Xbox compatible version of the Sender, does that mean if I had working hardware that was compatible with X-SIM I would get motion from all Xbox360 racing games or will it be dependant on extra software/hardware for this to work, I could build the hardware but I have no software knowledge. I have always liked racing games and the Xbox360 makes gaming easy. I would consider moving to a PC for my gaming but I would prefer to stay with the XBox360.
  6. bvillersjr
    Ohio, USA
    438Coins
    It means that if all goes well, a Force Sender like application will run on the X-Box, but will output its data to a PC that is running the Force Profiler and is connected to the actuators. There is an interesting matter of licensing and the fact that any non-microsoft API is considered illegal. However, Microsoft has added MMF support to the latest .Net Framework, which will translate into MMF support on the X-Box eventually.
  7. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
    If all goes well Does this mean you have already developed an executable API that will interface with the XBOX OS and capture those instructions? or will it reside on the XBOX hard drive?
  8. Les
    Les New Member
    Scotland
    0Coins
    Sounds interesting, do you have a rough timescale?
  9. bvillersjr
    Ohio, USA
    438Coins
    If my many other projects go smoothly, then I should have completed the proof of concept phase in 3 months. I will not be making use of any non-Microsoft API's if at all possible due to licensing restrictions. If the MIcrosoft API is too limiting, then I am aware of another API that will do the job, but technically, it isn't legal to use, therefore any such project would be open source and use at your own risk. I'm hoping to gather some support from Microsoft and fill in the API blanks in a legitimate fashion.
