Question Above 10 bit range possible with SMC3 ardunio sketch?
Discussion in 'SimTools Pro & Entertainment Version' started by Trigen, Mar 13, 2020.
  1. Trigen
    Trigen Active Member
    2,892Coins
    Im wondering if its possible to have a higher bit range and more resolution. Say 12 bit as im using Hall sensors. Also they do not move mor than 45 degrees. Would i need to write an entirely new ardunio sketch or is it possible to change it?
  2. Gadget999
    12,072Coins
    the limitiation is in the arduino - not the code
    use a later board and you can get higher resolution
    however in reality you will struggle to feel the difference between 1024 and 4096 steps of resolution on a sim
  3. RacingMat
    21,068Coins
  4. Trigen
    2,892Coins
    Ok thanks! Guess ill need to design a gearbox as im limited to about 250-300 steps in direct mode on my hall sensor. Or use a teensy
  5. BlazinH
    16,677Coins
    The issue with using most 12 bit adc microcontrollers is they operate at 3.3v and most hall pots are 5v. While their digital inputs are usually 5v tolerant the adc inputs aren't.
  6. Thanos
    Electronics Engineer
    2,907Coins
    It can be done with a inverted amplifier: https://forum.arduino.cc/index.php?topic=586505.0
  7. Gadget999
    12,072Coins
    Just use a 45 degree hall sensor
    You will get 1024 steps over 45 degrees
  8. Trigen
    2,892Coins
    How would the linearity be on this?
    Would you happen to have a link to one?
  9. Trigen
    2,892Coins
    Another question would be for a 3d printed 2:1 gear. Would the added 200-250 resolution vs the backlash and minor difference in the teeth make up for the loss? What about 4:1 (a lot more tricky to print due to size) and using the whole range seeing as its already maxed out around (see pic blue line) here.
  10. Gadget999
    12,072Coins
  11. BlazinH
    16,677Coins
  12. Gadget999
    12,072Coins
    that is accuracy to 0.05 degrees of movement over 50 degrees - good enough for me :)
    (accuracy to 0.19 degree over 180 degrees)
  13. Trigen
    2,892Coins
    I'd prefer making them myself and just buying the actual sensor as I have a 3d printer and lots of magnets. So the question is do I need a specific one that only measures 45 degree or a standard one and have the magnets in a special orientation. My current setup like mentioned (picture further up) does about 800-850 steps before the curve falls off and it reverses
  14. Gadget999
    12,072Coins
    the one i showed you is 50 degrees - they cost approx £15 !
    i would not waste your time - the sensor is an important part of the sim, you want to get it right first time
