DIY 4DoF motion simulator with Traction Loss
Discussion in 'DIY Motion Simulator Projects' started by the2jakes, Mar 1, 2020.
  1. the2jakes
    the2jakes Member Gold Contributor
    125Coins
    DC motor, Arduino, 4DOF
    I started wanting to convert my static racing simulator to dynamic/motion simulator 11 years ago. I finally started this convertion 2 weeks ago.;)
    Actual setup:
    - Thrustmaster Wheel T300RS, T3PA Pro pedals, TH8A gear box
    - Integrated 5.1 sound + Basspumps (similar to Buttkicker)
    -Wind turbine linked to acceleration
    -Curved projection screen + video projector
    Here's my static simulator:
    Curved screen in action:
    Using VR, it's allready very cool :):
    Other Creations:
    For the curious people arround here, here are some of the creations I made:
    -AIM Controller EVO for PS4:
    -ImmerSuit:
    -(for fun) 13 years ago I created this bulky VR headset, which worked with Live For Speed :
    Many other things on my youtube Channel:
    https://www.youtube.com/user/the2jakes/videos?view_as=subscriber
    Motion simulator building progress:
    Motion hardware:
    - 4 DC motors (400W) with reduction gears
    - 2 Sabertooth 2x32
    - 2 24V 40A 1000W power supplies
    - Arduino Micro
    Most of the motion stuff wiring is now done. I will soon power it up to do the first settings and tests (without the top platform). The 4th motor at the back is for the traction loss effect.
    I need to find out a way to have a rigid and strong top platform (my actual static simulator is mounted on a 15mm wood plank, and it's too flexible...):
    -Would you recommend extruded aluminium frame ? or steel ?
    • Like Like x 6
  2. the2jakes
    125Coins
    Today I made the 3 connectors:
  3. the2jakes
    125Coins
    Mobile chassis is now done. I’m a noob in soldering, so I hope it’s gonna be solid enough ;), it should (40mm steel tubes).
  4. the2jakes
    125Coins
    Chassis is now installed, everything fits perfectly, I’m happy :)
  5. the2jakes
    125Coins
    I’ve just positionned my original cockpit on the dynamic chassis to have a global look at it. Everything on the cockpit will be lowered (seat, wheel, gearbox, and probably the pedals by making a case under le metal chassis.
  6. Sam MAHENDRA
    Sam MAHENDRA mahentheman
    Electrical Engineer
    Sydney Australia
    395Coins
    Looks great. I can see that the Wheel is mounted on an adjustable rig. Did you buy the rig or made it yourself?
  7. the2jakes
    125Coins
    Hi, Thanx !
    I bought the steel mount that holds the wheel and seat. The rest is homemade.
    I will take off this steel mount because it’s heavy as hell, and it’s in the way of the pedals.
    I will probably use extruded aluminum with a different design... ;)
  8. Sam MAHENDRA
    Electrical Engineer
    Sydney Australia
    395Coins
    Thanks mate. Users of my car racing motion sim ranges from 4 to 85 year old!
    Since it's not practically possible to move the seat due to it being solidly fixed to the uni joint and the actuator rods.
    Instead, I wanted to make the pedal and the wheel to be able to move in both horizontal and vertical directions.
    I tried the scissor lift arrangement by first making one with timber to get the geometry correct (ScissorLift.jpg). It didn't work out well.
    So, I am now trying with the mild steel 25 mm SHS (Square Hollow Section) and 20 mm SHS. The 20 mm SHS glides easily with in the 25 mm SHS. One pair for the vertical and another for the horizontal directions. They can be moved independently and held in place by a bolt and wing nut inserted via a series of holes spaced every 50 mm.
  9. the2jakes
    125Coins
    Progression : 1st dynamic test ;)
    cockpit design has been made, and extruded aluminum ordered.
    Seat and « furniture » have been lowered to meet dynamic requirements:
    Next steps: re wiring of audio transducers, 5.1 sound system, wheel, pedals etc... and aluminum stand mounting. I have a 32inch curved screen also.
  10. Viktor_s
    Viktor_s New Member
    Russian Federation
    - 32Coins
    Hi! Awesome rig!
    Pls tell me nominal RPM of motors and gearboxes' ratio.
    For my opinion, steel profile most fine for you static base. Light and strong. Your weldering skills would be anough for that/)
  11. the2jakes
    125Coins
    DD6AB224-2E3E-47F0-BAFC-13C1CD6AD330.jpeg Hi victor, here are the motor references:
  12. the2jakes
    125Coins
    I’m mounting the cockpit right now:
  13. Sam MAHENDRA
    Electrical Engineer
    Sydney Australia
    395Coins
    Mate, I noticed that in your recent picture, there is a spring (looks like a car suspension coil spring) underneath the seat platform. What's the purpose of this spring?
  14. the2jakes
    125Coins
    Hi, there will be 3 of these springs. They help the motors a bit, because they support a part of the weight.
  15. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    Hi. Great rig.
    What is your maximum driver weight with this setup?
  16. the2jakes
    125Coins
    Well I don’t know. I weight 65kg and I had to drill the motor cranks at 5.5cm instead of 7cm because my mobile cockpit is heavy. Now it’s perfect, no motor stall anymore.
  17. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    It works well, unfortunately all my friends are >100kg :):)
  18. the2jakes
    125Coins
    Here’s a first test with Live For Speed.
    (Need to adjust Tuning center and forces, but it works).
  19. the2jakes
    125Coins
  20. James Thompson
    James Thompson New Member
    63Coins
    This looks like an awesome build mate...can I ask where you bought the motors from? I'm having a hard time sourcing them retail at the moment
