Andreas Ewe
Aerofly FS 2 Plugin 2.1.1.0
SimTools plugin for Aerofly FS 2
  1. kevinmarz
    kevinmarz Member
    346Coins
    yes I re- patched it...Guess I,m going to have to take another look @ it...thanks for the re-ply :]
  2. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    I'm a bit confused by the lack of euphoria about this. We lost motion control with FS2 about 2 years ago and no-one is saying "wow, finally its back this is great". It makes me think the new version doesn't properly work. I guess I'll have to find out for myself.
  3. Leandro Kemp
    Brasil
    - 10Coins
    Wow. :grin
    Non-Steam version has always worked well. This new plugin worked in the current steam version, but I was unable to adjust the anti roll over. H
    anyone managed to make this work well?
    In the roll to the left, the values in the tunning center are strange.
  4. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    You must be using absolute angles rather than acceleration forces. Is that right? Its the acceleration forces that broke.
  5. Leandro Kemp
    Brasil
    - 10Coins
    In the previous plugin it worked fine, but I don't know what angle value to put on this one. I've tried some and it didn't work. Can you send an image of the axis assignments and the tuning center?
  6. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    Haven't powered it up in 2 years since it broke, so I'm pretty rusty with the whole business, hence wanting some reassurance that the new plug in works before I try to get my head around it again
  7. Andreas Ewe
    Andreas Ewe New Member Gold Contributor
    Germany, Hessen
    229Coins
  8. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
  9. Andreas Ewe
    Germany, Hessen
    229Coins
    I'm not exactly sure about this, but during the plugin development I let write a debug file with timestamp for testing. I had definitly more values per second than 1. Maybe roundabout 10 times. So I think IPACS improved this. But I don't know the older SDK versions.
  10. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    Thank you again for the information. Everything points to this being back in action, despite the lack of publicity by IPACS even though they upset quite a few people when they broke it 2 years ago. I will get everything connected up again and see how i get on.
  11. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    Hi Andreas,
    I patched your plugin today and tried to run it with my original config. I noticed a few differences. Originally Extra1/2 were rate of bank/pitch, whereas you have been working with absolute angles. With the last IPACS SDK (when it worked), after a lot of experimentation and advice from others I found that rate of bank was a far more useful input than absolute bank angle, especially in VR. If you hold a 20 degree bank angle it feels more natural if the platform gently and unobtrusively returns to level rather than keeps you banked. I think this was the main issue with the SDK change, in that this acceleration data was lost. I think I concluded that pitch was OK as an absolute but not roll.
    Would it be possible for you to add rate of bank please or is it still missing?
    Similarly, am I correct in thinking that your surge/heave are velocities rather than acceleration forces?
    Incidentally how does yaw and traction loss differ? Yaw is an acceleration force already I see, rather than a deviation from some nominal straight ahead.
    Phil
  12. Andreas Ewe
    Germany, Hessen
    229Coins
    Hi Phil,
    I checked the sdk, but i was not able to find a "RateOfBank" value like "RateOfTurn" I used for yaw. I understand the need of that for roll or pitch. I attached a text file for you with all possible values which the sdk is delivering. Maybe one of these are the value you looking for. The output values for Extra1, Extra2 and Extra3 are still unused, so I will outlet the values you need there. No problem.
  13. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    Hi Andreas, this is great. I wonder about this one?
    AircraftAngularVelocity , "Aircraft.AngularVelocity" , tm_msg_data_type::Vector3d , tm_msg_flag::Value , tm_msg_access::Read , tm_msg_unit::RadiantPerSecond , "angular velocity in body system if 'Body' flag is set (roll rate pitch rate yaw rate) in global system" ) \
    My other thought is whether the rate of change of any of these values could be derived from the stream of values?
  14. Andreas Ewe
    Germany, Hessen
    229Coins
    Hi Phil. Thats right, for surge, sway and heave I used the angular velocities instead of acceleration. This is maybe incorrect. But so angular velocities ist already used. Easily switch roll and sway in Simtools Gamemanager. This should do the trick with turning back to center when rolling the plane.
  15. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    That is very interesting. I believe that sway is a lateral acceleration - are you saying that you have used a rotational acceleration? Similarly surge should be a forwards/backwards acceleration, is your a rotational acceleration in the forwards/reverse dimension? I diagram would be very helpful – I am on holiday at the moment just using my iPad otherwise I would happily assist.
  16. Andreas Ewe
    Germany, Hessen
    229Coins
    Andreas Ewe updated Aerofly FS 2 Plugin with a new update entry:
    Small fixes
    Read the rest of this update entry...
  17. andreassuter
    andreassuter New Member Gold Contributor
    Sschweiz
    - 37Coins
    DC motor
    Hall
    mein Flugsimulator und Einstellungen.
    Am Thanos AMC1280USB habe ich den PI Wert auf 15
  18. Arianus One
    Arianus One Tony Rom
    empleado
    - 32Coins
  19. Arianus One
    empleado
    - 32Coins
    on vr works this plugin?
    150,572Coins
    +11,017 / 55 / -2
    Yes it does.
