Resolved Stuck at Axis setting 2 dof Wheelchair Motion rig
Discussion in 'DIY Motion Simulator Projects' started by Tomsix, Jan 4, 2020.
  1. Tomsix
    Tomsix Member
    Németország
    324Coins
    Hi
    I want to introduce my DIY simulator that I want to use for flying and driving.
    The frame is made of stainless material. but not intentionally, it's just workplace residue
    After reading the Tutorials and choosing the sympathetic simulator type for me, I also ordered the electrical parts
    - Arduino Uno
    -2x IBT2 48A Boards
    - 10K Pots
    -2x 12V 30A LED Power Supply
    Here's a picture of how it looks put together, but without electronics
    But the joy is not yet complete, as there are serious problems.
    Everything works fine in the SMC3 Program during tests
    In the SIMTOOLS GAME ENGINE the on the AXIS test if i press Turn ON it does not stay centered but it drops the axis by about 10 degrees DOWN.
    When I move the slides, the axes move in the right direction ,however, they are not in a continous motion but bounces and dithers
  2. Tomsix
    Tomsix Member
    Németország
    324Coins
    This is a Video on Motion Test with SMC3
  3. Tomsix
    Tomsix Member
    Németország
    324Coins
    And the Test problem with Simtools Game Engine
  4. Tomsix
    Tomsix Member
    Németország
    324Coins
    I will try today to Reinstall the latest version of Simtools.
  5. Tomsix
    Tomsix Member
    Németország
    324Coins
    After I reinstalled Simtools 2.4 and configured the interface settings, the problem persisted and now I'm pretty clueless about what to do
    it is almost certainly the cause of something small but I do not know what
    153,884Coins
    +11,154 / 57 / -2
    You can't run the SMC3 utility and SimTools at the same time, as it seems to be in your video, as it will cause a port conflict.
  7. Tomsix
    Tomsix Member
    Németország
    324Coins
    They running not in the same time. I quit SMC3 and then run Simtools. U see in the background an opened window from the Simtools Tutorial.
    I will try the same setup with an other Pc to see what happens
    153,884Coins
    +11,154 / 57 / -2
    In that case I suspect you need to refine your SMC3 settings further, including deadzone.
  9. Tomsix
    Tomsix Member
    Németország
    324Coins
    I found the error ...
    So the point is to set the local setting to English in my case this caused the simulator to behave strangely
    Everything is working right now, I've done my first laps in Life 4 Speed, now without any load
    153,884Coins
    +11,154 / 57 / -2
    @yobuddy thought he had squashed that particular bug in the latest SimTools, but apparently not, so will likely have to hunt it down a bit more when he has a chance :(
    What language setting did it happen with?
  11. Tomsix
    Tomsix Member
    Németország
    324Coins
    Swiched from Hungarian language to English
