I've problem with 2.1.4 beta
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by XRiccardo, Oct 3, 2009.
  1. XRiccardo
    XRiccardo New Member
    1Coins
    ...with sender. It's more instable. I don't have a internet connection active when i try it. The sender not appear in the bar at the bottom, the drop-down menu does not work, it crashes.
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Try unplugging your internet connection and making sure that no wireless adapter is attempting to discover a network BEFORE starting the profiler and sender. I have found that wireless adapters when struggling to find a connection will cause major X-Sim problems. It is best to not use wireless network adapters in your simulator. Also, I have seen X-Sim freezes on Vista when wireless networks are attempting to re-negotiate link speed, which you may not even know is occuring. It seems that Vista does something crazy when this re-negotiation occurs. I'm guessing that the force sender is using synchronous communications as opposed to asynchronous communications. This means that it is expecting good network communications and rapid response to it's internet requests. When these re-negotiations occur, it doesn't get these rapid responses and the thread hangs. Again, this is just a guess based on my observations. SirNoName may be able to comment further about the nature of the communications.
    You can avoid all of this by having a stable NON-WIRELESS internet connection, or by having no wireless card installed in your PC, and ensuring that no network cables are plugged into your PC.
    I ran X-Sim 2.1.0.3 at a trade show with no internet connection for a week straight all day long with only one small unrelated glitch.
    All of this having been said, if we get to vote, I too vote for removal of the community features and simplification of the sender!
  3. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I also agree on the removal of the community features or at least the ability to disable them.
    ....Mike
  4. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    812Coins
    How to convert your old profiles?
    I tried adding zero's to the max value but that does not work, seem really difficult.
    But i like the new smooth feeling of this version, is it even possible to 'convert' your favorite profiles?
    Now i only use Nima's Gtre profile with 2.1.4 and when playing other games i just install the 2.1.3 version of X-SIm....
    Is there a trick for this or do you have to build your profiles from the ground up?
    I can't really, hope someone has a solution.
    Regards,
    Rob
  5. voodoo
    voodoo New Member
    0Coins
    Hallo,
    ich komme mit der Profilkonvertierung auf 2.1.4 auch nicht zurecht. Was muß ich genau ändern, damit diese Meldungen (Warning outdated profile) aufhören?
    Code:
    [Overall]
    includesaxisdata=1
    includesaxissynaptrix=1
    includesaxisuso=1
    includesgauges=1
    includesusoconfig=1
    includesprogramconfig=1
    numberofaxis=0
    profileversion=2
    [ProgramSettings]
    SynaptrixTaskPriority=2
    MathTaskPriority=2
    MainTaskPriority=2
    MathPause=10
    SynaptrixPause=33
    holdposition=0
    centerdelay=-1
    autohwscan=1
    autoisolate=0
    [Autostarttrigger]
    autostarteffectnumber=1
    autostartenabel=0
    autostarttriggeronplaying=0
    autostarttriggeroncreated=0
    autostarttriggeronplugin=1
    [GaugeSlotAxis]
    visualaxis1=1
    visualaxis2=2
    visualaxis3=3
    visualaxis4=4
    visualaxis5=5
    visualaxis6=6
    [Gauges]
    minimizeall=0
    minimizestartup=1
    gaugename0=LCDExport
    gaugeconfigfile0=Speed: Current speed (m/s, kmh or mph)
    gaugetype0=0
    gaugename1=LCDExport
    gaugeconfigfile1=RPM: rounds per minute of engine
    gaugetype1=1
    gaugename2=LCDExport
    gaugeconfigfile2=Tire temperature: back right outer
    gaugetype2=22
    gaugename3=LCDExport
    gaugeconfigfile3=Current lap: number of current lap
    gaugetype3=5
    gaugename4=LCDExport
    gaugeconfigfile4=Best lap time: best lap time driven
    gaugetype4=6
    gaugename5=LCDExport
    gaugeconfigfile5=Last lap time: last lap time driven
    gaugetype5=7
    gaugename6=LCDExport
    gaugeconfigfile6=Tire temperature: back right inner
    gaugetype6=20
    gaugename7=LCDExport
    gaugeconfigfile7=Temp of water: current temperature
    gaugetype7=9
    gaugename8=LCDExport
    gaugeconfigfile8=Tire temperature: back right middle
    gaugetype8=21
    gaugename9=LCDExport
    gaugeconfigfile9=Aircraft: Oil temperature of an aircraft
    gaugetype9=32
    gaugename10=LCDExport
    gaugeconfigfile10=Fuel: Current fuel of a car in liter
    gaugetype10=2
    gaugename11=LCDExport
    gaugeconfigfile11=Tire temperature: front left outer
    gaugetype11=11
    gaugename12=LCDExport
    gaugeconfigfile12=Tire temperature: front left middle
    gaugetype12=12
    gaugename13=LCDExport
    gaugeconfigfile13=Tire temperature: front left inner
    gaugetype13=13
    gaugename14=LCDExport
    gaugeconfigfile14=Tire temperature: front right outer
    gaugetype14=16
    gaugename15=LCDExport
    gaugeconfigfile15=Tire temperature: front right middle
    gaugetype15=15
    gaugename16=LCDExport
    gaugeconfigfile16=Tire temperature: front right inner
    gaugetype16=14
    gaugename17=LCDExport
    gaugeconfigfile17=Tire temperature: back left outer
    gaugetype17=17
    gaugename18=LCDExport
    gaugeconfigfile18=Tire temperature: back left middle
    gaugetype18=18
    gaugename19=LCDExport
    gaugeconfigfile19=Tire temperature: back left inner
    gaugetype19=19
    gaugename20=LCDExport
    gaugeconfigfile20=force sender input #11
    gaugetype20=53
    gaugename21=LCDExport
    gaugeconfigfile21=force sender input #12
    gaugetype21=54
    gaugename22=LCDExport
    gaugeconfigfile22=force sender input #13
    gaugetype22=55
    gaugename23=LCDExport
    gaugeconfigfile23=Position: your current position in game
    gaugetype23=8
    gaugename24=
    gaugeconfigfile24=
    gaugetype24=-1
    gaugename25=
    gaugeconfigfile25=
    gaugetype25=-1
    gaugename26=
    gaugeconfigfile26=
    gaugetype26=-1
    gaugename27=
    gaugeconfigfile27=
    gaugetype27=-1
    gaugename28=
    gaugeconfigfile28=
    gaugetype28=-1
    gaugename29=
    gaugeconfigfile29=
    gaugetype29=-1
    gaugename30=
    gaugeconfigfile30=
    gaugetype30=-1
    gaugename31=
    gaugeconfigfile31=
    gaugetype31=-1
    gaugename32=
    gaugeconfigfile32=
    gaugetype32=-1
    gaugename33=
    gaugeconfigfile33=
    gaugetype33=-1
    gaugename34=
    gaugeconfigfile34=
    gaugetype34=-1
    gaugename35=
    gaugeconfigfile35=
    gaugetype35=-1
    gaugename36=
    gaugeconfigfile36=
    gaugetype36=-1
    gaugename37=
    gaugeconfigfile37=
    gaugetype37=-1
    gaugename38=
    gaugeconfigfile38=
    gaugetype38=-1
    gaugename39=
    gaugeconfigfile39=
    gaugetype39=-1
    [Calibration]
    numberofsequences=0
    calibrationtype=0
    [Axis0]
    Axisname=Axis 1
    isasymetricoffset=1
    calibrationoffset=0
    numberofmath=0
    USODivider=1
    USOMultiplier=1
    USOAdd=0
    USOBandwidth=0
    USOValuetype=0
    [Axis0Synaptrix]
    synaptrixnote=
    numberofspeeds=1
    directoutputstring=
    directoutputport=none
    referenceinputstring=
    referenceinputport=none
    refmin=0
    refmax=4294967295
    invert=0
    sensibiltiy=0
    globalminimumpwm=0
    moveandstop=1
    inertia=0
    numberofstopports=0
    speed0name=single speed or dynamic output
    speed0enablevalue=1
    speed0numberofpositivepulses=0
    speed0numberofnegativepulses=0
    [USOConfig]
    numberofcoms=0
    startupfix=0
    Ich kann hier keinen G-Force oder Acceleration Wert finden und erhöhen. Vielen Dank vorab für eine kurze Anleitung.
      966.2 KB
      588
