Showroom FlyPT - 6DOF Brushless DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by pmvcda, Aug 29, 2017.
  1. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    yes , I have SFU 1605
    ok , it the same thing of your set up !
  2. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    I have SFU 1605
    Yes , between each limit switch I have 480 mm - holder block who active each switch have 40 mm = near from that 450 mm
    see this video ( actuator 1 and 3 don't move ) and number 2 dance like a sine with some stop mouvement ! Done with Mover sine that you sent me !
    You can see too the relay who active each actuator with green led or no !
    I swapped ESP32 = samething no change , after I swapped board support of esp32 = no change .
    Realy strange !!!
  3. pmvcda
    15,583Coins
    I don't know if the relay solution is good. I think you need another solution.
    The movement you get is wrong, it should go up and down smoothly.
    It's trying, but the speed variation is not reaching the controller as it should
  4. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Hi ,
    After this wonderful weekend off with my wife on vacation:grin, I thought precisely that opto relays need 5 volts to work well and esp32 gives us 4.6 volts with the booster. So I'll see to find a PSU 5 volts and try this …
    Thanks !
  5. F-Zero-One
    F-Zero-One Member Gold Contributor
    derby, derbyshire
    22Coins
    SUCCESS!!!!!! but I did have to swap the limit pins on actuator 1 and 3 for some reason was really confusing, but I followed the all the diagrams and I now have two working actuators.
    Cant seem to upload video though
  6. F-Zero-One
    derby, derbyshire
    22Coins
  7. F-Zero-One
    derby, derbyshire
    22Coins
    Although I have both actuators moving I have one question, why would the mins/max be different by so much?
    am I missing hall sensor counts somehow??
    I'm using BLDC8015A+57BLF03 motors/drivers
  8. pmvcda
    15,583Coins
    Try to swap the actuators.
    0 in 1 and 1 in 0 to see if the counts also swap.
    If they don't, vthen you might have something wrong in the connections. Just swapping one of the hall wires is enough for this difference.
  9. F-Zero-One
    derby, derbyshire
    22Coins
    Not sure what you mean by swapping? in order or hardware?
  10. pmvcda
    15,583Coins
    In hardware
  11. pmvcda
    15,583Coins
    I mean the plugs in the board
  12. F-Zero-One
    derby, derbyshire
    22Coins
    I think I have a bad hall sensor there's nothing on pin 35 so I get 4,5,1 but not 6,2 and 3 in the sequence
  13. pmvcda
    15,583Coins
    Could it be a cable or bad connection on the Connector. When you swapped plugs, the error also swapped right?
    If so the problem is in the plug, cable or motor
  14. F-Zero-One
    derby, derbyshire
    22Coins
    Yes the problem followed the cable. I am checking the cable this evening. but I am impressed with the build and your design, very good, once i get this sorted I will attach to you flypt control and see what happens, but yeah thanks I have learnt a lot.
  15. F-Zero-One
    derby, derbyshire
    22Coins
    All working, it was something on the PCB luckily I had made two lol, always have a plan B,
  16. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Newss … finaly relay opto work well with 3.3v and 4.7 volt ( from Esp32) and with the PSU 5 volt it the same . the problem is not there …..:(
    The only thing I can see now is the mix of signals with the same* level shifter* because I dont have 5 of them but only two ( red) and diferent !
    May be the interference Signal Direction and PWM with the same * level shifter* are not friendly together .
    Now I know : 1- feedback sensor from all motors are good .
    Next step will be : signal PWM 3.3volt direct to the drive (my drive have pot and ampli to accept 0-10 volt) and Opto direct from output ( ESp32)
    Like this , only the sensor motor will be with level shifter .
    I give you up date !
    Thanks !!!
  17. F-Zero-One
    derby, derbyshire
    22Coins
    FYI if the hall sensor pins are swapped U <---->W then the numbers will be swapped
  18. ReBorn
    ReBorn Member
    238Coins
    sooo.. I just bought the ACT MOTOR 57BLF03 101mm 24VDC 3000RPM +1PC BLDC-8105A-5 for 83€ and all of the Hardware for one Actuator and controller. All the Parts should be arriving in the next two weeks. And im pretty sure I am going to have a lot of questions ;)
  19. ReBorn
    ReBorn Member
    238Coins
    not able to edit the messsage.. I allready have the first question: Do you think a OYY AC-DC 24V 16.7A Power Supply 400W can handle one Actuator?
  20. F-Zero-One
    derby, derbyshire
    22Coins
    I hope so as I have these motors/drivers and 1000w PSU and I have a third motor coming this week, so I'm hoping this will be ok, so one should be ok
