Codemasters F1 2019 plugin v2.0.1
SimTools plugin for Codemasters F1 2019
  1. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    Hello, today I tried again to play with F1 2019.
    The settings into the game are ok, I've the plugin 2.0.1.0
    When I start F1 2019, the game manager is blue
    The tunning center receive a lot of information
    My issue is the seat is crasy and move also when the car is stopped
    do you have a idea ?
    thanks
    151,668Coins
    +11,045 / 56 / -2
    Could you pleas post pictures of all of your settings, including the Tuning Center while the game is running.
  3. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    F1_0.jpg Hello, please find the pictures
  4. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
  5. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
  6. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
  7. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    when the game is stop
  8. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    When the game runing
  9. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    Did you try it in DX11 UDP legacy mode?
  10. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Yes in DX11 and tested with lecagy, 2018 and 2019
  11. yobuddy
    50,816Coins
    @Foehn,
    Can I see a pic of your sim buddy?
    Then I can help with some settings.
    Take care,
  12. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Hello @yobuddy
    What do you means a picture of simbuddy ?
  13. noorbeast
    151,668Coins
    +11,045 / 56 / -2
    @yobuddy means pictures of your rig, so he knows what configuration it is and hence can offer some setup advice.
  14. DoubleM
    Amsterdam
    - 23Coins
    Try heave around 7 and sway also.
  15. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Using my SCN5 motion setup and Simdisplay Simr-DLX.
    Running SLIMAXmanager Pro, Simtools and F1 2019 DX11 in UDP=legacy mode through Sim Race Proxy Server works fine for motion. (Not for Simr-DLX display)
    Changing UDP to 2019 formaat works fine for Simr-DLX display but gives uncontrolled jerky motion.
    Does anyone has a workaround ?
    and
    Does anyone know if the 2019 UDP format can be changed to legacy within the Sim Racing Proxy Server ?
    regards,
  16. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Motion platform, 4DOF
    Same happens with Simhub, Simtools and F1 2019
    any update on this?
  17. DoubleM
    Amsterdam
    - 23Coins
    Can you change the F1_2017 Plugin to look for target F1_2019.exe
  18. Mu-KwangKim
    South, Korea
    - 689Coins
    It seems to be the same as Windows local configuration problem.
    Control Panel-> Regional Settings-> Administrator Options-> Change System Local -> English (US)
    change it this ~
  19. nornesnaj
    Netherlands, Zelhem
    125Coins
    F1-2018 with simtools & simhub is running just fine.
    However i cannot get F1-2019 simtools & simhub to run together.
    tried everything i have read in the forums but no sucsess
  20. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    if opening, try to close Fanalab (or other)
